Swapping 96-99 Center diff to 4th Gen Torsen Center Diff
Old Dec 26, 2006 | 04:57 AM
dmenheere's Avatar
1st post so go easy on me
Just wondering if it would be possible to swap my 96 part time center diff over to the 4th generation torsen center diff. I would like to do this because of the snow/ice/bare pavement conditions encountered in this part of the country, not so much this year yet ... weird weather.
I have figured out that the center diff changed to a longer diff with multi-mode (99-02), and requires the driveshafts to be shortened/lengthened ~3", see this link
http://forums.delphiforums.com/n/mb/...y&msg=102444.1
which gives you the fulltime 4wd. Reading up on the 4th gen where the torsen center diff (VF4AM) was introduced
http://www.toyota120.com/GenDocs/2003_4Runner.pdf
it mentions that the one of the new designs benefits is a shorter overall length of 50mm(~2"). Can the driveshafts absord a 1" difference in length?
I know there is some wiring to figure out since the shift lever is replaced with a rotary switch but this shouldn't be impossible. Maybe its possible to use the manual shifter without going to the fancy rotary switch.
The transfer case should bolt up to the transmission since they are both A340F.
thanks for any input,
cheers,
Old Jan 15, 2007 | 10:44 AM
KyleT's Avatar
just find a 00-02 center diff and get the driveshafts at the same time.
I would imagine that trying to get the 4th gen compatable with the 3rd gen electronics might not be fun.
Old Jan 15, 2007 | 11:27 AM
Good Times's Avatar
you're going to encounter some problems here:
1. the 4th gen tc's are all electronic and not stick lever. this means that you'll have to play with a lot of the electronics to make it work.
2. i am certain the bolt pattern on the tc's are the same but if you're going this route why not get the 00-02 tc since it's almost the same?
Good luck
smthwsn357
May 1, 2024 07:28 AM
jerusry
Oct 19, 2015 05:28 PM
nick9455649
Sep 11, 2015 05:10 PM
HRDC0R19
Jul 5, 2015 06:43 PM
ptb12
Jul 5, 2015 01:49 PM
