New Richmond 4.88 IFS gears + BJ Spacers and more.
Old Dec 5, 2006 | 03:09 AM
Ganoid's Avatar
Well I sold the TruTrac so I will list some other stuff I guess.
1) New unused set of Richmond 4.88's with the paper work (box died) 100$ SOLD
2) Set of used BJ spacers $65 you will need to buy new bolts as I cant find the ones I took off. SOLD
3) Set of upper and lower IFS control arms with Energy Poly bushings already installed (4-5 mos old) and cut for BJ spacers with all mounting hardware still attached $45
If any one would like any spindles or steering linkage just pay the ride as it will probable get scraped if no one wants it. Most of the front end parts are fairly new Toyota OE stuff according to the receipt the PO left in the glove box for $2100 (OUch!)
Buyer pays shipping unless you want to come pick it up.
Old Dec 5, 2006 | 07:44 AM
89red4x4yota's Avatar
i want dibs on the gears! are they front and rear? how much is shipping to 02809? might want the ball joint spacers what size are they??? let me know
Old Dec 5, 2006 | 11:51 AM
Ganoid's Avatar
The spacers are the standard 1.5"
The gears are for the 7.5" IFS front diff.
I will go check shipping.
25# to your zip is cheapest via fedex ground @ $23
My Zip is 97303 if you want to do more checking.
Old Dec 5, 2006 | 01:31 PM
ok i may just do the front ball joint spacers...any pics is there hardware?
Old Dec 5, 2006 | 07:33 PM
dantheyotaman's Avatar
if he doesn't take the bj spacers put me in line for them,
Old Dec 5, 2006 | 07:35 PM
CJM's Avatar
CJM
3rd in line for the spacers if no one else goes through with it.
Old Dec 6, 2006 | 03:14 AM
Ganoid's Avatar
Its just a matter of who ever wants to pony up $65 and pay shipping or in dantheyotaman's case he could show up at my door and pick them up. My Zip is 97303 Salem,Or if some one wants to figure shipping its just 2 spacers so maybe 8# tops but I'm just guessing I can weight them tomorrow I guess.
Old Dec 6, 2006 | 04:13 AM
yeah im pretty sure it goes by weight to find out shipping...still interested
Old Dec 7, 2006 | 12:50 AM
Ganoid's Avatar
Just figure $6 for shipping and I will cover the rest (shouldn't be more than a few $ over that).
Old Dec 7, 2006 | 03:06 AM
Buck01's Avatar
Sorry not trying to horn in on your sale.
Just thought I would mention I have a set of BJ spacers I would sell as well.
New never used.
Old Dec 7, 2006 | 04:34 AM
ganoid are we looking at $71 shipped?
Old Dec 7, 2006 | 08:47 AM
Ganoid's Avatar
sounds good to me.
Old Dec 9, 2006 | 08:24 AM
funds are a little tighter then i thought...next semester and xmas is coming bump to the top for the next in line....hate to pass them up!
Old Dec 9, 2006 | 08:29 AM
CJM's Avatar
CJM
I gotta drop out, for 65 bucks andmaybe another 10 from RB for the hardware it woulda been great..but I be broke now
Old Dec 9, 2006 | 08:49 AM
4x4Travis's Avatar
Do the spacers require any modification to anything, or do they bolt right in?
Old Dec 9, 2006 | 01:00 PM
Ganoid's Avatar
You will need to clearance the underside of the control arm.
Old Dec 9, 2006 | 01:48 PM
drew303's Avatar
You gotta cut the inside of the upper control arm. google 4crawler (he posts on this board to)... not sure if thats where you got the BJ spacers to begin with Ganoid?
Thats where i got mine.
Need a grinder to do the upper arm clearing, takes awhile but once you get the metal out of the way they bolt in.
Word of caution, stock yota driveaxles will bind at full drop, atleast mine did with the 1.5" spacers. I had to fab some bumpstops to keep the arms from dropping to the point where the axles bind.
ive been reading here the stock T100 axles fit and are of a different CV joint that doesnt bind as easy. Research it i guess.
fabbing the bumpstops was a PITA tho
edit* ... i dropped the front axle like an inch to, not with 4crawlers drop but my own fab job with some spacers (spare bed mount weld on body lift spacers) :-p
The axles didnt bind as bad but still required new upper bumpstops.
Old Dec 10, 2006 | 09:11 AM
guess that puts me next in line.....
ganoid you have a pm
Old Dec 11, 2006 | 04:13 AM
Ganoid's Avatar
I wonder if Toyota changed axles throughout the years because I had no binding at all with my axles using the stock bump-stops. When I replaced all the front end bushings I had it all back together except the torsion bar bolts. I was then able to cycle the suspension full droop to full compression to check shock length and for any binding to which I had none. I didn't have any sort of diff drop either just factory mounts.
Old Dec 11, 2006 | 03:00 PM
yotaman89's Avatar
im interested in the gears my zip is 34481 let me know a price
