Window regulator question
Old Jun 4, 2026 | 05:25 PM
Kla's Avatar
Kla
Hello all. I have an 85 pickup with manual window regulators. The problem is that the passengers side window will come out of the window regulator if you attempt to roll it down. The rubber piece that the glass sits in inside of the regulator itself is gone. Its not in the bottom of the door either. Was trying to find one online with no luck. The regulator operates as it should. Does anyone know where to find one?
Old Jun 4, 2026 | 08:17 PM
aztoyman's Avatar
You can use make shift rubber or similar material shim to wrap around the glass and get it to wedge in place. An automotive glass shop may have something. You can even use some sort of adhesive. IDK if there's a factory part available but you can look it up. I know most of the glass run stuff still is. I ordered mine from Amayama.
Good luck with it and please follow up with your fix.
Old Jun 5, 2026 | 02:25 AM
Kla's Avatar
Kla
Thanks for the info.
Toyota80man
Jun 4, 2022 03:21 PM
hamburg99
Jul 13, 2015 09:54 PM
punks_is_4x4
May 31, 2015 07:50 AM
4x4Lamm
14
Feb 29, 2004 04:25 PM
