Original stereo re-install
Old 09-23-2018, 06:50 PM
billoddity's Avatar
hi folks, I’ve had a million Toyota’s so I’m fairly versed... I’m into 80’s/early 90’s cars and a bit of a weirdo when it comes to keeping or returning them to stock condition. I have a basically new 1993 4Runner that is completely stock except the stereo. It’s been unusually complicated trying to replace the crappy pioneer CD player with the CD/Cassette stereo that originally came in this model 4Runner. First of all, that particular stereo was rare as most models just came with the cassette and cubby below. Then a few of the stereos adapt to the tiny factory amp and other identical stereos don’t. I’ve purchased 6 Oem Toyota cassette/CD stereos that have varied slightly in design and all of them have had failed cassette players in some way even if stated otherwise. I’ve purchased two from a stereo reman specialist and just returned the first because the cassette clicked loudly while playing music. The second has arrived and also clicks loudly. I’m wondering if it’s at all possible that I am under powering or mis-wiring the unit or some other issue that is causing the cassette portion to click during playback? On this particular stereo, it is from a 1997 4Runner so I have bypassed the amp. Everything sounds great and works perfectly except the cassette players. Any thoughts?
Old 09-23-2018, 07:11 PM
old87yota's Avatar
It is hard to tell without actually seeing the problem in action.
Is the click in the cassette deck itself, or is the click audible through the speakers?
Did you try another cassette tape?
Cassette decks fail over time due to cassette tape residue on the playback head and pinch rollers, belts getting old, and mechanical linkages binding up with dust and old grease.
I do not know much about the factory head units with separate amplifiers. Do you need another amplifier if you are not using the stock one?
Try posting a video of the problem if you can.
Old 09-23-2018, 07:19 PM
billoddity's Avatar
It’s only in the head unit itself, sounds rotational with the tape. Seems unusual that it would be the same in multiple stereos. I’ve tried numerous cassettes.
Old 09-23-2018, 09:02 PM
Co_94_PU's Avatar
Refurbish it!
Good thick white grease, nylon safe.. Sorry I don't have a specific product for you.
Could be a weak or tight spring also.
Pull the covers off, maybe loosen the cassette tray, and you should be able to find the culprit while it's in action.
Take lots of photos, we really like picture stories around here kinda like toddlers.
Old 09-23-2018, 11:20 PM
wyoming9's Avatar
Red face
From what I remember the cassette tape drives were the weak links in these units .
I recall they always failed first then parts could only be found from other units no longer working .
Which really limits being able to rebuild them.
Old 09-24-2018, 03:39 AM
Co_94_PU's Avatar
Modern 3d printing has come a long way from the rough prints we used to have, or so they keep telling me
Old 09-24-2018, 06:39 AM
billoddity's Avatar
I currently have 7 early 90’s Toyota stereos that won’t work in some way. Two are unusual 14 pin connections and I have 4 that are all the same aside from two of them go to the amp and two of them don’t. I will try to test all of them and see if I can find one that works. I get a little lost inside the tape compartment, not sure what to make of all the little levers and springs etc. I will check back for input.
Motomeister
11-07-2022 02:07 PM
SomedayJ
11-10-2017 12:14 PM
mikey060
14
10-31-2013 12:16 PM
Jordanlawrence
08-23-2013 04:39 PM
kingbiscuit
7
02-12-2009 05:51 PM
Quick Reply: Original stereo re-install
