1993 Front Shock Bushing & Retainers
Old 09-20-2018, 09:30 PM
Colorado4x4's Avatar
1993 4x4 xtra cab pickup: Front stock shock absorber install, trying to figure out the proper sequence of the retainers and bushings in relation to the top shock tower
Anyone know if part 48510C shock retainer (see parts diagram below) goes on the bottom of the top rubber bushing (on the top of the shock tower) or does it go on the top of the bottom rubber bushing (on the underside of the shock tower) ??
1993 Truck front shock mount
Basically where is the shock tower situated in this shock absorber diagram
Old 09-21-2018, 12:01 AM
wyoming9's Avatar
Red face
Just what new hardware did you get with your shock ?
Most aftermarket shocks come with 2 rubber bushings and 2 shaped washers .
Just like your picture is
Old 09-22-2018, 08:36 AM
I'm using OEM shocks and hardware to reinstall.. My intuition says that the middle retainer (48510C) goes on the bottom of the top bushing (thereby on the top of the shock tower)
Old 09-22-2018, 08:46 AM
wyoming9's Avatar
Red face
I have never seen original shocks on a vehicle this old sorry
Old 09-22-2018, 10:02 AM
Andy A's Avatar
correct, it should have a lip on it that fits in the hole that the stem goes thru
Old 09-22-2018, 10:23 AM
iwanttobelieve's Avatar
Just did all my shocks and from what I recall the top cushion had a little extra material that mated with the frame mount hole. From top down it should be:
1. Nut
2. Retainer
3. Cushion
4. Frame Mount
5. Retainer
6. Cushion
7. Retainer
8. Shock
From the 2nd gen FSM:
Pauly67
09-21-2011 05:59 PM
blue87
01-10-2008 03:48 PM
skife
11-13-2007 11:22 PM
KZN185W
05-13-2006 11:35 AM
Quick Reply: 1993 Front Shock Bushing & Retainers
