Help! Maf Sensor Connector broke
Old 07-17-2018, 10:32 AM
luisugueto90's Avatar
Hello! first poster here. I've got a 2.7 4 cylinder Prado that I've messed up.
Removing the lid on my air cleaner assembly to replace my air filter, I broke one of the three wires going into the MAF connector plug.
I've soldered it back in place, but I don't really trust it much.
Does anyone know where I can source a 3 pin connector plug for my truck's MAF Sensor?
Old 07-17-2018, 08:00 PM
TheDurk's Avatar
http://wilbo666.pbworks.com/w/file/f...RM1022E%29.pdf
If you just broke a wire, you probably just need a repair wire, which is the pin with a short length of wire attached. Remove pin from plug, insert repair wire and splice. This shows you how and gives you the p/n's for the wires. You can also get the plug housing if you really need it but it comes without wires. The only source for a ready 3-wire pigtail is a junkyard.
Old 07-18-2018, 05:39 AM
Thanks for the reply.
The wire broke just at the edge of the pin, inside the connector. I took apart the plug and just barely managed to join the pin and wire. It got me home, but I don't trust it to hold much longer.
I'm going to need, at best, a new pin to properly repair the plug. If it were possible, I'd rather get a new plug, new pins and pigtail to properly repair and extend the plug so this doesn't happen again.
That manual is one hell of a resource, but I can't seem to find tha part numbers for the pin/plug. Any ideas where to look?
thanks!
Old 07-20-2018, 05:30 PM
TheDurk's Avatar
thanks!
You should be able to find the connector p/n embossed on the housing. Look for a 5-digit number. The p/n is that number preceded by 90980-. If no number, locate the connector by using the pictures. They are separated by waterproof/non-waterproof and number of pins. It's not that hard to do. Once you have the connector p/n, then you can look in the second part for the repair wires used on that plug.
For what you describe, a single new repair wire will do the job better than a new plug/pigtail...which they don't sell anyway.
Old 07-25-2018, 05:09 AM
Thanks a lot!
Done, Found it, i'm ordering a brand new plug.
davidbr93
04-30-2018 03:42 AM
emmantik
03-14-2014 07:35 PM
RcBro
3.4 Swaps
01-16-2014 05:40 PM
DWEINBERG01
07-29-2008 06:33 AM
Quick Reply: Help! Maf Sensor Connector broke
