'87 Turbo Restoration and Build
#161
Nice!
#162
^^ Yes!
You are doing things right. Keeping yourself organized takes out the frustration of "where do these bolts go".
Just working on things a bag or two at a time will make the bags of parts less scary.
The picture would be much scarier if all of those parts were just rolling around in a box somewhere, unlabeled!
Good luck!
Good luck!
#166
Looking great!
How's your camber after the ball joint spacer install?
I had to bring mine in quite a bit.
You are progressing so quickly. It's fun to watch. I've fallen behind on mine!
#169
Rear Bumper is done. It was a bear! One bolt broke off for the mounting brackets and I had to drill it out. Glad this one is done and all worked out in the end.
#170
I’m sure my alignment is off. I’ll do a driveway alignment once all the weight is back in.
#173
Not Ideal! The ‘85 flawless front wheel well moldings don’t fit the ‘87 - ugh! So I did my best to fix my damaged ones and put them on till I find a replacement.
Also so installed the power antenna with the new mast.
#177
#178
As you may have seen from my other thread on the topic, I’m a little worried about the 32x11.50s rubbing on the upper A-Arm now that the 1.5” BJ spacers have pushed the upper arm up and toward the tire more.
I trimmed the lip on the Upper A-Arm and added a thin 1/4” wheel Spacer in the front. Let’s hope they clear - abou 1“ clearance right now.
