Jackhammer noise in 4wd turning on a steep road..
Old Apr 28, 2018 | 12:42 PM
BlackPearl808's Avatar
profile of damage
Old Apr 28, 2018 | 12:52 PM
millball's Avatar
Originally Posted by BlackPearl808
profile of damage
Looks pretty deep. If it was me and I had another undamaged carrier at hand, I'd use it.
You can buy brand new ones; here's one on Ebay;;;;;
https://www.ebay.com/itm/Nitro-Stand...oAAOSww5hZLyKE
Old Apr 28, 2018 | 02:29 PM
When I take off the other 3rd, I'll choose the better of the 2.
I am aware of the re-gearing of the front. I just want to get her back on the road again.
Old May 2, 2018 | 05:41 PM
I checked out a donor truck and I am a bit confused..
It's an 89 V6 Automatic with manual locking hubs which I thought would be great as I wanted to re-gear. But, when I looked at the VIN plate:
it's saying G292 which is 8" with 4:10's and 2 pinion which is what I have on my 4cyl. According to LCE Toyota mislabeled some trucks as having 2 pinion. When I looked under at the diff:
it did have the 4 fins that would indicate that it was the 4 pinion type. I wonder if they mislabeled the gear ratio as well. I guess the next step would be to
raise the truck and spin the wheels, right? if it's closer to 4 revolutions of the tire then it's the 4:10 and closer to 4 and a half it would be the 4:56?
Anyone with a V6 automatic that can drop some diff knowledge?
Old May 2, 2018 | 05:50 PM
akwheeler's Avatar
I don't know much about 2 or 4 pinions, but I do know it will be 4.1 rotations of the DRIVELINE for ONE rotation of the tire for a 4:10 and if you don't move both tires together it will throw you off. So you are better off marking your driveshaft and slowly pushing the truck forward in gear while you watch how many times it turns (mark the tire also so you can get one rotation).
Old May 10, 2018 | 04:02 PM
so I finally got to wrenching on the rig today..bought me an '89 V6 as a parts truck mostly for the rear differential.
I took out the old one and I didn't know I was running a welded diff. I'm no expert but I think they did a pretty
$#!++y job, well because the weld failed and there are weld splatters? everywhere.
The side gears were pretty chewed up. I'm wondering, could the little bits have caused the whole thing to fail?
Also, I had a hell of a time pulling on the passenger axle shaft (broke a slide hammer)
Check the pics:
Can't really tell but the teeth were all busted up inside:
Well, back to work, I need to get my rig going, the lava's coming!
Old May 10, 2018 | 04:51 PM
millball's Avatar
Chunks of steel from any source certainly can trash a diff.
Even the welding itself can pit the bearings if not careful with the grounding.
Hope you're not really close to that lava....
Old May 10, 2018 | 11:48 PM
I'm about 5 miles as the flow cries.
millball, it says on your signature that you have v6 brakes on your 87. I had to use the passenger rear axle shaft from my v6 parts truck with the brakes attached to it. Does that mean that I have a v6 brake too? The splines on the old axle shaft had about 1/2" at the tip that was completely gone. I was hammering on the thing for a while but decided to be smrt & search yotatech..Good thing I didn't mess up the new (old) third!
Old May 11, 2018 | 08:00 AM
millball's Avatar
Far as I know, it's only the front discs and calipers that are larger. Rear drum brakes are Same-same.
5 miles is a piece, but with volcanoes, who knows?? Good luck.
Old May 11, 2018 | 02:46 PM
Mahalo
