Why is my computer doing this? (pic)
Old Jul 5, 2006 | 08:39 AM
MudMonkey's Avatar
Everything slows down during a spike (page loading, streaming video, scrolling, typing, smilie animation) and not just in firefox, it's system wide.
I can't figure it out.
Old Jul 5, 2006 | 08:42 AM
Churnd's Avatar
Which process is doing it?
Old Jul 5, 2006 | 08:43 AM
MudMonkey's Avatar
it would seem firefox is doing it
Old Jul 5, 2006 | 08:47 AM
Churnd's Avatar
It might be due to an extension, or plugin (Java comes to mind). Try FF in safe mode and see what happens. If it runs safe, then try to track down the extension or plugin and either re-install it or remove it.
Old Jul 5, 2006 | 08:49 AM
MudMonkey's Avatar
Screen cap during spike...
Old Jul 5, 2006 | 08:52 AM
CLin9383's Avatar
firefox is hogging your system. i dont use firefox much, but if you have an older version there is a memory leak problem. if you have 1.5 or higher then the problems lie elsewhere.
Old Jul 5, 2006 | 08:56 AM
MudMonkey's Avatar
I feel like an idiot now... 3 out of the 4 extensions I use needed updates...:smack:
How do I keep Firefox, or any other program, from hogging resources?
Buck01's Avatar
check for spyware or some other BHO browser helper object.
Old Jul 5, 2006 | 08:59 AM
MudMonkey's Avatar
running a scan now...
Old Jul 5, 2006 | 09:15 AM
MudMonkey's Avatar
scan came up with nothing major.
Old Jul 5, 2006 | 09:16 AM
Buck01's Avatar
what tool did you use to scan?
Have you tried HiJackThis or spysweeper?
Old Jul 5, 2006 | 09:19 AM
MudMonkey's Avatar
I use Spybot: Search & Destroy
Old Jul 5, 2006 | 09:21 AM
Buck01's Avatar
I use spybot,HiJackThis and spysweeper. They all clean some things...none of them get everything. Try one of the others...If you need help with Hijackthis save the scan to a text and place it here...
Old Jul 5, 2006 | 10:40 AM
Churnd's Avatar
Like Clin mentioned, older versions have memory issues. Are you using 1.5?
Old Jul 5, 2006 | 01:09 PM
midiwall's Avatar
Hey Chris... Install this:
http://www.sysinternals.com/Utilitie...sExplorer.html
It'll show you a ton of information about an app, including open files and I/O specifics. It may help to narrow down which extension is doing this or if it's FF itself.
You can set it up as a replacement for Task Manager (it's a menu option) so it's handy to get to when it happens.
What's your plugin list look like? Does this happen on a regular basis or is it random? How long does the "event" last for?
Old Jul 5, 2006 | 01:16 PM
MudMonkey's Avatar
Chris, I just downloaded the newest version...we'll just have to see how it goes.
Mark, I downloaded that program, too... Now I just need to figure it out.
Old Jul 5, 2006 | 01:25 PM
midiwall's Avatar
Just pull the EXE out of the zip file and drop it in a folder somewhere. Run it, then click Options | Replace Task Manager.
I think it defaults to showing the "lower pane" but if not, then View | Show Lower Pane.
When the event happens, hit CTRL_SHIFT_ESC (hold each one until you've pressed all three) to bring up Tsk Manager (which is now this app) then click File | Save As.
Enter a file name, and check out the fun. Post up the text file here as an attachment if yoou'd like.
Old Jul 5, 2006 | 01:34 PM
MudMonkey's Avatar
Jeez, Mark... Give me some credit...I know how to unzip a .zip file...lol
Old Jul 5, 2006 | 01:38 PM
midiwall's Avatar
sorry... I read the "just need to figure it out" statement a bit too literally.
Old Jul 5, 2006 | 03:51 PM
Churnd's Avatar
When it comes to this stuff, that's never a bad thing.
