Home Network Question
Old Mar 13, 2007 | 04:07 PM
linuxrunner's Avatar
Sorry if the title is vauge, but i do not really know how to ask this question...
ok so i am hosting a (windows server 2003) streaming media server and the server has remote admin enabled but i am haveing trouble getting to both the streaming music and the remote admin (Also running webserver and that works just fine) to work from outside my network i am sure it is some ports that i forgot to forword or something, the problem is that i have a wireless router that goes through a wired router then to firewall then through the modem. So there is like 4 devices that it needs to be forworded through and changeing one setting at a time then going to school and testing it is going to take FOREVER. My question is... is there a way i can go out of my network and come back in from my home? Becuase from inside the network everything works great i just need a way to test comeing IN through the routers/firewall without needing to physically go somewhere else to test it. Sorry this is long but it is kind of hard to explain what i am looking for.
Old Mar 13, 2007 | 07:00 PM
reggie 00's Avatar
set up tightvnc to access your computer from school and then log out and test it.
http://www.tightvnc.com/
its pretty easy to use, its what i use so my bookkeeper can access my computer and balance my books for me. If she can do it anyone should be able to.
Old Mar 14, 2007 | 08:33 AM
Churnd's Avatar
Two options off the top of my head:
  • Get a switch and put it in between your cable modem and other hardware. Though your ISP will see you pulling two IPs at once, and may not like that.
  • Set up a DMZ on your hardware and put the machine you want to be "outside" your internal network in it. This may be harder since you have multiple routers. http://en.wikipedia.org/wiki/Demilit...ne_(computing)
You may also want to look into a VPN, if your hardware supports it. Hamachi is good for this: http://www.hamachi.cc/
Old Mar 14, 2007 | 10:12 AM
li_runner's Avatar
I'll second using a DMZ, I use sonicwall normally.
I don't understand the need for a wired and wireless router, just use the wireless, and a switch.
the1998sr5
15
Jul 14, 2020 08:35 PM
coleypull15
Nov 3, 2015 07:41 AM
pyramid
Jul 29, 2015 06:53 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
