Help getting replacement monitor
Old Sep 12, 2009 | 01:41 PM
4mydogs's Avatar
My old monitor (4:3) died, and I found myself looking at replacement monitors that are all widescreen versions. The only two stores in this area stock NO 4:3 monitors, so I picked out the least expensive one and brought it home. It's a Dell 19". When I hooked it up it didn't look great, of course, because the display resolution for my old monitor was set at 800x600 (I think).
Disclaimer: I'm computer stupid. I don't know about operating systems, I don't download newer versions of stuff. I only use it for internet surfing, work spreadsheets, and some simple photography stuff. My motto: If it ain't broke, don't fix it.
Okay, so I now notice that my new monitor's "Optimal" display resolution is 1440x900. My computer's graphics driver has 8 resolution options
800x600
1024x768
1152x864
1280x720
1280x768
1280x960
1280x1024
1360x768
and of course none of them are the recommended 1440x900. I did some reading and found that most 19" monitors operate on 1280x1024, so I set the resolution at that and it didn't look very good at all. I tried every setting, and the best is the 1360x768, but still I am not liking it. My monitor's paperwork tells me that if my computer doesn't have 1440x900 as an option, I may need to update my graphics driver. I've spent an hour looking at Dell's website and trying to see what that is going to take, and it doesn't look good for me to try doing it. There are like 8 different upgrades, and I can't tell which one would give me this resolution. Finally, here's my question:
Do I
1. Suck it up and go through whatever it takes to download and install the right driver to give me 1440x900? Or
2. Do I go to the other store and buy (I saw this after I brought the Dell home and hooked it up) a Samsung monitor whose optimal resolution is 1370x768, only off by 10 pixels (horizontal) from my computer's option of 1360x768, and return the Dell? I would think that the display should look pretty fine with the resolution that close.
3. Try hard and find an old-style 4:3 aspect monitor? I was perfectly happy with the old one until it died.
What do you think?
Old Sep 14, 2009 | 04:18 PM
4Crawler's Avatar
You might see if the driver update is available, but if the existing video hardware only supports the resolutions listed, then that may be all it will do (that is if that is hard wired into the hardware). Many monitors have a function to have them optimize the display for a given resolution, might see if yours does that. Or if you have an empty slot in the PC, grb a new graphics board, I recently put a low end Nvidia chip-set based board in my Gateway and it has every resolution imaginable. Hooked up the new monitor (after the old one died) with a DVI cable and it works fantastic.
Old Sep 14, 2009 | 06:59 PM
24Runna's Avatar
1440 x 900 is a 19" widescreen monitor.
Download the newest graphics drivers. What computer do you have?
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
1994toyota
Jul 17, 2015 03:03 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
