DVD Shrink Users READ!
Old Nov 22, 2004 | 07:59 AM
Churnd's Avatar
I've always used the straightforward method to backup my DVDs... just let it run non-stop until the final DVD is burnt. However, this weekend I was forced to stop the process halfway... as in, the DVD was copied to a folder on the hard drive, but did not get burnt to the blank DVD.
What do you do to get the files burnt properly to a DVD after that? I can't find anywhere in DVD shrink that allows you to do this, and I tried to use a different program, CDBurnerXP, to just burn all the files in the DVD folder, but that didn't work.
What to do?
Old Nov 22, 2004 | 08:07 AM
jacksonpt's Avatar
Senior Member
I do this a lot... I still use DVD shrink. Normally, you'd use the open disk icon, rip the DVD, the burn it. When the files are already ripped and stored on your computer, use the Open Files icon, find the files, then do the same as you normally would.
Old Nov 22, 2004 | 01:16 PM
Corey's Avatar
Co-Founder/Administrator
Same thing.
Sometimes I do not have time to let ut burn all the way, so I will just let it burn the files to a folder on the drive called:
c:\movies to burn.
Inside are 3 sub folders,
one
two
three
I always rip to # one.
When doing is as Jackson mentioned by going back and clicking on open files, I browse to the one folder, but then have to input below # two, as when it looks at your files already on the PC, it decrypts them once more, but it only takes a few minutes, and the output at the top of the screen is to my burner.
So you end up with two folders them each containing the same # of files and MB.
http://www.pnw4runners.com/temp2/dvd_shrink.jpg
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
