computer help
Old Apr 17, 2005 | 11:54 AM
Jared Ajlouny's Avatar
computer help
i have a IBM R50e laptop and i need to bring it to school to do a power point. i pluged the 1 prong connector into my laptops port and nothing came on on the projector. the tea cher than tested it on his comp and it worked fine. my dad said there is a button i need to press for it to work anyone know?!?! thnaks
Old Apr 17, 2005 | 03:57 PM
green91runner's Avatar
1 prong connector? got a pic, im thinking you mean rca? cause s-video has about 5 pins, and theres 40 in a dvi, or 15 in svga. usually theres a key to push, with dells, you hold down the function key, then press the key with the pic of the 2 displays or with the labeling 'crt/lcd' (after its been connected)
Old Apr 17, 2005 | 07:48 PM
i ment 15 prong
Old Apr 17, 2005 | 08:28 PM
yea, looking at the tiny internet pictures of your laptop, you should have the function key in the bottom left region of the keyboard, then up in the F keys, or number keys, there should be the screen toggle (in the same colour as the function key) if you cant find it. go to your desktop properties, then go to settings, you'll see 2 boxes, one with a '1' and one with a '2' right-click on the '2' and click attached. the projector should kick in.
Old Apr 18, 2005 | 02:25 PM
CynicX's Avatar
its probably different with all computers....with my Toshiba I need to press ALT-F5 after its plugged into the projector or tv....there is a little pic of an LCD screen next the F5 print...good luck, check the manual if you have it and maybe even call IBM tech support
kawazx636
Oct 6, 2021 03:03 PM
some drunk guy
Aug 3, 2021 06:09 PM
dbollier123
Sep 29, 2015 05:23 PM
