GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Which Noise Filter?
Old Apr 20, 2006 | 01:36 PM
  #41
4x4Lamm's Avatar
I had super good luck with a cheap one from Advanced Auto Parts the Metra Auto Works elcheapo model to be precise.
Lamm
Old Apr 20, 2006 | 06:01 PM
  #42
kvanderploeg's Avatar
This probably won't be the full solution to all of your problems, but here's my shot at your problem. First, and this will sound crazy, but take a good old roll of aluminum foil and start wrapping all of your plug wires with it. Make sure that all the foil is connected to a good ground. Be careful, as a charge may build up on the foil if you don't ground well enough.
After you've covered them all in foil, try your radio out again. If you see a significant difference, you will want to find some "EMI shielding tape" as a more permanent solution. I'm not sure where the best place to find this would be, but Mouser.com will probably have it. I believe 3M is one of the largest manufacturers, but there are probably others. You can probably get someone on the phone from Mouser and have them make a recommendation about a product that is heat, oil, and chemical resistant.
You might also want to find a good braid material and bond all of your doors and trunk to the body. This will help shield out unwanted RF energy from the vehicle as well. Good luck!
Old Apr 21, 2006 | 07:29 AM
  #43
deathrunner's Avatar
Good ideas. Mine seemed to be better on the last trip, but it is still abit noisy, it breaks through the squelch when I'm throttling.
I haven't had the time or resources to get into it.
Let me know how the noise filter works out, Yota4Runner.
Old Jul 21, 2006 | 09:56 PM
  #44
hlpressley's Avatar
Sorry to bring up an old thread but I am having the same problems and was wondering if you guys had come to any conclusions.
crammit442
7
Nov 29, 2017 12:30 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Iceman4193
Aug 28, 2015 08:43 PM
norcal98
Aug 10, 2015 06:20 AM
calderp
Jul 27, 2015 09:58 AM
