need help finding a ground
I am trying to install a cobra 75 wxst and i couldn't find a ground. The factory grounds wouldn't work. The only ground that would work was the neg. terminal on the battery and that fried the wires. Any suggestions.
JD
JD
JD
JD
http://www.drawhorn.org/cobra_75_cb_...ary_fuse_b.htm
Good luck!
If the "factory grounds" wouldn't work, then I have to ask if you're hooking it up correctly. You should be going Red to positive and Black to ground. A switched positive lead can be found at the back of the cig lighter, factory radio, off the ignition switch, etc. You can also run straight to the battery, but it's not really recommended since you could leave the radio on accidently and run the battery down.
Depending on what you mean by the wires being "fried", then I would guess that you had a short. Did the fuse blow? If not, then the radio is probably toast.
Before you try hooking up the radio again, let's define what you did up front.
coffey50
Jul 28, 2015 10:55 AM
v_man
Jul 23, 2015 04:01 PM
HookahRoo
Jul 20, 2015 07:06 PM
scottyg486
Jul 19, 2015 05:34 PM
