GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
cb worked when removed and now it doesn't
Old May 16, 2007 | 09:28 PM
Hayes's Avatar
I installed my CB and it workeed flawless. I snipped the wires so that I could install a quick connect, got it all set up and it doesn't work. Took it all apart, checked the fuse, etc, etc. All the lines are run properly and now it still doesn't work.
I'm out of ideas and I need the CB for tomorrow...
I'm going to go to the shop I bought it from and see if they have any ideas, but any help would be appreciated.
Old May 16, 2007 | 09:34 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
is there no power at all? try checking the battery ends of your quick connects to see if theres a circuit, if there is, either something coincidentally fried in the cb (not likely) or something on the cb end of the quick connects
Old May 17, 2007 | 05:05 AM
Hayes's Avatar
all the ends are connected...crap
Old May 17, 2007 | 07:28 AM
TXST8tj's Avatar
did you wire it straight to the battery? or another location?
in my jeep, i had my CB wired with a quick disconnect so i could take it in and out to avoid theives. i also wired a switch inline with the power wire to cut the power before the quick disconnect so i would not blow fuses. once the metal ends of the disconnect touch, they are just like bare wires touching and will generally blow the fuse. by flipping the switch and cutting the power, i was able to disconnect and connect without that connection having any juice. i.e., flip the switch to "off" to disconnect, that way you don't touch something in the process. also, when it's time to put it back in and reconnect, the line will not have any power, so you will be ready to connect without having to remember to flip the switch to "off". once it's all connected, flip the switch back to "on" and you're ready to rock and roll. the more connections and splices you make with a CB, they more interferance you risk; however, i would rather risk that over blowing fuses everytime i take it in and out.
Old May 17, 2007 | 12:11 PM
Hayes's Avatar
That must be my problem. Got a new fuse and all is well!
Old May 18, 2007 | 01:23 AM
Merlin's Avatar
the in line switch is a great idea! i have a quick-disconnect for my radio as well (makes it quick to remove when servicing vehicle, etc...) but i never thought about the bare ends in the quick-discos causing problems. thanks for the great idea! got a project to work on this weekend now...
Old May 18, 2007 | 02:56 PM
TXST8tj's Avatar
i used a very simple (and cheap) switch. i mounted it under the dash in the jeep because it wasn't something i felt like i needed to permanently drill a hole and mount somewhere. if i had a full switch panel or something, i could see doing it.
Jun 1, 2021 01:51 PM
DacodaYota
Sep 2, 2015 02:13 PM
bigblue82
10
Jul 6, 2015 08:27 AM
gog1968
Jun 22, 2015 05:55 AM
