GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Cb antenna ball mount. tell me about it
Old Jul 28, 2011 | 08:01 PM
  #41
85gijunk4x4's Avatar
Originally Posted by irab88
there is. i suggest going straight from the antenna base to a bolt on the frame. part numbers 69925k11, 69925k12, and 69925k13 are pre-made grounding straps with lugs, 30", 36", and 48", respectively.
is there anyway to make my own? and when you mean go straight from the antenna base, do you mean where the antenna screws into the antenna mount, or one of the bolts for the mount that go into the bed of my truck?
Old Jul 28, 2011 | 08:39 PM
  #42
irab88's Avatar
you can probably buy some of the strap material and crimp (with a bamf of a crimper/press) tin-plated copper terminals on. to get the width of the terminal once flat, add one-half the diameter to the wire gauge. eg, a terminal for 1/0 gauge cable will flatten to just about .5", good enough for a .5" braided strap
Old Jul 29, 2011 | 03:47 AM
  #43
xxxtreme22r's Avatar
you don't wanna go from just the antenna base to the frame. You have to think different with an antenna then an electrical connection. You want to make the bed grounded which it sounds like it's not. Just grounding the antenna to the frame isn't gonna ground the bed. You have to ground the bed to make the bed the ground plane.
Old Jul 29, 2011 | 06:33 AM
  #44
irab88's Avatar
hmmm... didn't think of that, brandon. what is really needed is one of these (but not practically)
Old Jul 29, 2011 | 06:39 AM
  #45
haha yeah, not needed really, but that bed has to get grounded to the frame. However, if the bolts go from the bed mount on the bed through the 4x4 and into the frame like mine did, he should be ok. But even still I would ground strap 4 corners of the bed. 1" recommended but half inch should work ok if he's not running power. Which he's not.
Old Jul 29, 2011 | 06:51 AM
  #46
irab88's Avatar
the only thing i'm not too sure on is how to terminate the wires. i know i said that stuff previously, but many terminals only go up to 4/0, so if you wanted 1" straps, you'd need a huge terminal.
apparently, from looking online, you can cut copper tubing and smash lat around the end, then drill a hole through the new "terminal" and braid all at once
Old Jul 29, 2011 | 07:07 AM
  #47
I think he will be fine with the 1/2" predrilled type braid. And I imagine since there is predrilled stuff, you can use a 1" and put a metal grommet in it or simply two washers just like the predrilled stuff, no need to actually use a terminal connector. I wish I could find that bonding article, but I think it was on wilson's website and has since been deleted. I know I posted that link on here before somewhere in the communications section. I think I need to start making some stickies for CB stuff. As I find myself answering alot of questions regarding such.
Old Jul 29, 2011 | 08:13 AM
  #48
okay so the only right way to do it would be grounding the bed, by adding straps at each corner. You said if im just running four watts half inch should be okay? i might just bump it up to an inch just because though
Old Jul 29, 2011 | 08:18 AM
  #49
irab88's Avatar
sounds good to me. what about you, radio station x22r?
Old Jul 29, 2011 | 08:33 AM
  #50
lol Ian, yeah 1/2" should be OK with a 4w stock radio. You can get that stuff already pre-drilled.
Old Jul 29, 2011 | 08:39 AM
  #51
sweet, thanks guys. 4 watts is about all im ever gonna run. I just gota mesure today to see what length i need. Should i go to the frame, or would be putting the predrilled hole on the Bed mount bolt and adding a jam nut be ok? i dont know what im going to do yet, i'll have to look at it to see wheres good to mount.
Old Jul 29, 2011 | 08:50 AM
  #52
bed mount bolts will work, ideally though you want it between the nut and frame that has been ground/stripped down to metal, but they might be too big for the 1/2" straps. I believe that hardware is 12mm ??? or something like that. I know my bolts right now are 1/2" bolts.
Old Sep 6, 2011 | 03:54 PM
  #53
well, that's if the bed frame is electrically connected to the frame (ie, through bolts). if your lights are grounded to the bed frame, you'll be fine
so if my tail lights, turn signals etc. are grounded to the bed, AND work, i'll be fine?
i know when i re-did my side lights, instead of grounding to the frame, i touched the wire on the bed and they came on...
does this mean i DONT have to bond my bed to the frame?
Old Sep 6, 2011 | 06:32 PM
  #54
irab88's Avatar
as i understand it, "grounding" for antennas is completely different than electrically. as long as you have a metal plane at the base of the antenna, you'll be fine. when you attach it to the metal bedside, that becomes the ground, whether connected to the battery or not. however, you will get weak signals from the dirrection where there is the least amount of ground plane. for example: you mount the antenna on the left side of your bed. since most of the bed is to the right of the antenna, signals will be sronger on that side, and realitivly weak to the left of the antenna (due to the lack of bed, or "ground plane" to that side).
hope that helps. i can draw something up if need be.
Old Sep 6, 2011 | 06:43 PM
  #55
uhmmm. You kinda lost me there irab...
I'll keep reading it and see if i can understand it
Old Sep 6, 2011 | 08:28 PM
  #56
irab88's Avatar
--antenna's ground needs to be attached to a big metal thing (like your metal bed). that is the "ground plane"
--the metal thing (ground plane) does not need to be connected to the battery's ground
--the direction that the metal goes from the antenna will give the best signal
sorry for rambling, but i meant to say ^those^ three things. a diagram would help... hang on a sec...
Old Sep 6, 2011 | 08:38 PM
  #57
irab88's Avatar
Old Sep 8, 2011 | 09:16 PM
  #58
Merlin's Avatar
actually, they have ground planes for mobile use, it's basically a chunk of metal with a 3/8 drilled hole for the antenna stud to screw into, with three radials coming out of the sides.
it goes onto the mount on your bumper, roof, whatever, and then you mount the antenna to that. adds a bit of height, but depending on where you mount it, some claim it works.
i've seen them with really long radials (parallel to ground, not diagonal like the base antennas), not really sure if they work better because the ants are already mounted on the roofs of 'burbans, cargo vans, etc... so i figure the ground plane should be pretty solid.
i've also seen fighting sticks with radials coming out the top, kinda like using a base antenna on your mobile. not for daily driver use, but i'm sure they make a difference in keydowns where you can only run one hot, or a single antenna.
Old Nov 16, 2012 | 11:35 AM
  #59
heres a question for Irab88 (or whoever else wants to chime in)
I installed a cb in my 86 the other day, mounted the antenna through what i'd call the bed rail, that flat piece about almost an inch long on the top of the bedside that seperates inside of the bed from the outside. Just drilled through the channel and used one of these mounts
mounted a Wilson flex (thanks to brandons suggestion) on the back passengers side, pretty much right above the pass. side taillight.
as far as i'd thought, the cb antenna itself had to be grounded (to the frame, and such), so I ran a 10 gauge wire from the antenna mount to a spot on the frame wich I grounded down bare and ran a self tapper through.
my radio is a dinky little trc-446 I pulled out from my 85, mainly because it was small and I liked the way I had it mounted.
my co-ax is about 12" I think? ran it behind the bedside panels, along the frame then up through a hole in the firewall....I used just about every inch of it so theres not coils of wire hanging out.
the problem I've been having is that the s.w.r. wont come down (its in the red) and it doesn't stay steady, it likes to jump around rapidly +/- 2ish.
tried different radios and different antennas and I can get none of them to tune.
so did I mess something up with my ground? ground it in the wrong spot? should I try bonding the bed to the frame and grounding it to the frame? run no ground at all?
Old Nov 16, 2012 | 11:40 AM
  #60
irab88's Avatar
try it without that ground wire at all. did you try it without the tuning tip in at all?
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
crash813
Sep 27, 2015 07:15 AM
