GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Antenna mounted up, pics inside
Old Mar 6, 2005 | 09:34 AM
fiveofeen's Avatar
Okay well go easy on me, it was the 1st try. I like the way its setup but I am doing it wrong I just know it. I couldnt find anywhere to mount it where it would be on metal. So I grounded it with a wire. I think I should be using a "no ground" antenna maybe. I am going to test the ground on it later on today. I checked it and got a response and the guy said it sounded good, we were only about a 1/2 mile apart and I lost him quick. Here are the pics, this thing is friggin tall!! I am definatley not sure its going to stay here, but its a nice clean spot for it.
Old Mar 6, 2005 | 08:58 PM
fiveofeen's Avatar
18 views an nothin! common yotatech, well I got another radio check tonight and got responses from two or three others from home based CB's I think. Both about 1.5 miles away in different directions so that was good. threads sure arent as fun when your the only one in em. Hey brian (epic) thanks again for giving me that CB.
Old Mar 6, 2005 | 09:20 PM
epic37311's Avatar
LOL... Yea it was clipped you should get a pretty good radious on it. Hmmmm maybe you should learn spanish
Old Mar 6, 2005 | 09:21 PM
epic37311's Avatar
by the way the higher up you go the better off you are. Center of the vehicle is pretty good.
when you are an "expert" try this link out http://www.signalengineering.com/ult...na_basics.html
Old Mar 6, 2005 | 09:52 PM
epic37311's Avatar
Something to remeber :
If you live in an area where rain and/or sleet is common, wipe your antenna down with a rag that has been coated with WD-40, Armor-All, Pledge, light oil, etc. This trick prevents ice build up that can overload and cause your antenna to break. In an emergency use butter, cooking oil or anything else that will repel water.
Old Mar 6, 2005 | 10:25 PM
96LtdYota's Avatar
also watch out for parking garages and going through the drive through at fast food places... antennas will break, i seen it...
Old Mar 7, 2005 | 04:22 AM
fiveofeen's Avatar
yeah its just too big for the drive thru. i smacked the 9ft clearance sign and watched the antenna wobble for a few mins.
Old Mar 7, 2005 | 12:23 PM
Erich_870's Avatar
Your set up looks pretty good for range. The best is always going to be on the center of your roof, but that always looks lame IMO If you want the best range and don't need it all the time you could look at magnetic antennas that you'd throw up there when you want it, so drive thru’s and parking garages aren't a problem.
I also kind of wonder if the mounts on your wind deflector can handle that extra stress from your antenna at hwy speeds. I don't have a wind deflector so if it’s not a problem, I'll shut up.
Looks like it work pretty well though.
Erich
Old Mar 7, 2005 | 03:01 PM
fiveofeen's Avatar
Erich
Yeah thats what I am wondering. They seem to hold up well. I have used them to pull myself up onto the bumper before. Yes not the smartest thing to do. It seems stable though. I really like the spot its in, the only other place I might move it to is By the tailgate, obviously that will be lower then.
Old Mar 7, 2005 | 07:15 PM
Marc P's Avatar
Looks like a good place. How did you run the antenna wire?? Where did you get the mount?
Old Mar 7, 2005 | 08:29 PM
Erich_870's Avatar
I guess if it passes the chin up test then it should be fine
Look into a quick disconnect and you'd have the drive thru problem solved.
Erich
Old Mar 8, 2005 | 08:45 AM
fiveofeen's Avatar
the mount is a L shaped mirror bracket. I ground off one corner so it would fit inside the small area. The coax is not hidden yet, it runs alongside the rear window and through the tailgate crease. I am thinking of running it through the 3rd brake light pod. Drill a lil hole, put a grommet in it. There isnt any room under the rear window trim for the coax, so thats not a choice.
Old Mar 8, 2005 | 12:52 PM
epic37311's Avatar
Looks pretty clean so far. Pretty good job on the install.
Old Mar 8, 2005 | 04:11 PM
Darx's Avatar
You mihgt want to consider getting Firestik's heavy duty spring to put on there. It will save you if it hits something.
Scotto6591
Sep 1, 2015 03:24 PM
TDonkey
Jul 26, 2015 10:14 AM
toofly1999
Jul 25, 2015 07:09 PM
jon.r
Jul 11, 2015 03:34 PM
