Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Where/How did you run the Amp Wire?
Old May 1, 2005 | 10:08 PM
wsudu's Avatar
I have a 3rd gen and I want the Amp under the seat. Where did you guys run the amp wire? i am guessing the firewall. I didn't know if there were any secret places. I see where there are a cluster of wires going through by the fuse box.....is that good? Let me know thanks
Old May 1, 2005 | 10:13 PM
ish's Avatar
ish
which wire to the amp? there are quite a few.
for mine i ran the power from the battery through the hole on the firewall (driverside) and then under the carpet along door sill. the rca cables i ran along the center console then under the carpet
Localmotion's Avatar
yep..thats what i did. I ended up drilling another hole for my other wires, so i re-wired them through the new whole
Old May 1, 2005 | 10:15 PM
green91runner's Avatar
sorry to hijack, but.. wouldn't putting your amp under your seat be a bad thing if your running the wires to the back, was under the understanding that you want the wire from your amp to your sub to be the shortest possible (mine is about 10")
Old May 1, 2005 | 10:36 PM
I have 2 amps. I have one under my seat and one in the rear.
Old May 1, 2005 | 10:39 PM
nieuwendyk-25's Avatar
Also mounted mine under the seat. Ran it through the firewall with its own hole and grommet. Like this:
Old May 2, 2005 | 11:03 AM
Bigkahuna808's Avatar
I have 2 failry large whole is my FW to run my power wire. The amps are atached to the back of the rear seat. I pulled the drivers seat out and ran all my wires under the carpet.
Old May 2, 2005 | 12:14 PM
williemon's Avatar
If you run a large enough guage wire to the subs, it could be 10 feet and not degrade the sound at all. its the GROUND wire that should be as short as possible. Even with a large guage wire.
Old May 4, 2005 | 05:58 PM
Dekri's Avatar
When I hooked up my amp, I wanted it under the seat as well. But I was warned that if I put it under the seat it would over heat and blow fuses more than it should. I mounted mine on the backside of the back seat closest to the subs as possible.
Just thought I'd throw that out there. Can't prove that theory since I never had the amp under the seat. I thought I'd just pass what I heard on.
Old May 5, 2005 | 08:44 PM
Originally Posted by Dekri
I was warned that if I put it under the seat it would over heat and blow fuses more than it should. .
Under the seat in most cars should get plenty of air flow. I have mine under the seat in my 2000 Runner and it barely gets warm, even cranked. I used to have a pull out Alpine headunit and it got so hot in the dash, you could iron your pants with it....seriously!
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
smiley52
Jul 11, 2015 05:16 AM
nick b
Jul 11, 2015 04:38 AM
toyota32
Jul 6, 2015 05:42 PM
