Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Where to ground an amp?
Old Jan 10, 2006 | 01:40 PM
ato178028's Avatar
I have a 2000 4Runner and was wondering where the best place in the cargo area to ground an amp. I would like to use an exsisting bolt if possible.
Old Jan 10, 2006 | 01:44 PM
Bob_98SR5's Avatar
grounding to an existing bolt is not recommended, especially since it is a device whose fluctuating power requirements require a good, solid ground.
i highly recommend the rear cargo (flat) area. there's plenty of places to choose from. also, scrape off some paint with a dremel sanding drum, pilot a hole, drill it and then secure a bolt/nut (or a metal screw) for a solid connection.
bob
Old Jan 10, 2006 | 02:44 PM
Bumpin' Yota's Avatar
A wire wheel will work as beautifully as and easier than a sanding drum.
But I agree.
Old Jan 10, 2006 | 06:56 PM
t100's Avatar
i grounded my amp to my seat bolt... seems to work fine...
Old Jan 10, 2006 | 09:26 PM
ato178028's Avatar
I guess something else is wrong with my setup because it wont work when I ground it there. I will go back and check over everything in the morning.
Old Jan 10, 2006 | 09:47 PM
msw0085's Avatar
same here.. just sanded the paint off..
Alexdosdall
Dec 10, 2017 05:48 PM
live4soccer7
May 11, 2016 06:52 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
charlie_fong
Sep 27, 2015 10:06 PM
toyotasaurus
Sep 24, 2015 03:30 PM
