Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
stereo wire diagram for '89 4runner
Old Oct 11, 2004 | 07:41 PM
wuduhel's Avatar
can anybody tell me which wires are which for the stereo in an '89 4runner? the stock harness has been cut. i suppose i could check them all with a multimeter if i had to, and if it comes to that, how would i go about doing that?
thanks
Old Oct 12, 2004 | 03:01 PM
wuduhel's Avatar
ok, i found a diagram showing which wires are which, but in the diagram a couple of colors are missing from what i have in the 4runner.
also, i don't have a black wire, but i do have a brown wire.
which is ground, 12volt and ACC?
Old Oct 12, 2004 | 06:58 PM
Zonie4Runner's Avatar
Brown should be the ground, but you're better off to run the ground from the head unit directly to a good ground on the frame (no more than 18" wire though or resitance gets high) ... your accessory wire should be red and your battery wire should be blue/yellow.
Old Oct 12, 2004 | 08:08 PM
wuduhel's Avatar
ok, i went ahead and wired it up already
the blue/yellow 12volt lead wasn't giving any juice so i ran a lead directly from the positive terminal on the battery. it's a pretty long lead, at least 5'. is this too long? do i need a fuse? if so, what amp?
i wasn't sure about the ground, so i ran a ground lead to the chassis in the engine bay. it's more than 18" and it works. i'll make a shorter lead tomorrow.
the factory ACC lead was getting juice when the ignition was turned on, so i went ahead and used it. it's gray by the way.
all in all, the radio is working nicely. i'll clean up the install when i get a chance.
Old Nov 3, 2004 | 04:36 AM
smiljko's Avatar
Where did you found a diagram?Culd you put a link?
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
steve miller
Oct 10, 2015 01:40 AM
Jdgarrison
Oct 1, 2015 05:22 PM
toyota32
Jul 6, 2015 05:42 PM
