Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
putting a system into my reg cab.
Old Mar 1, 2011 | 06:18 AM
drift_king's Avatar
so just throwing something around, i dont have that money but im a teen with dreams haha, i was thinking of taking some like 10 subs, put one behind each seat then screw the amp into the back wall of the cab what does everything think about that im interested in your guy's input
Old Mar 1, 2011 | 06:21 AM
Bojangles's Avatar
I did this, its possible. I had two tens behind the seat, But you need to build your own box. 5 1/2 inches at the bottom, and 3 1/2 at the top. You'll have to slide your seat up 1 click or so but you can make it work. (Hope your not tall)
I built two seperate boxes, one for either side of the truck, and put the amp in the middle.
I spent 100 dollars in my system with two 10's and a 400watt amp and i was putting guys with 12's to shame.
Ill draw something up for you and post it if i get a chance.
Old Mar 1, 2011 | 06:28 AM
drift_king's Avatar
sounds good, thnx for the response, im excited to see this draw up, once i get the money this is gonna be good haha, also im thinking about amping the door speakers while im at it what do u think?
Old Mar 1, 2011 | 06:53 AM
scottishb's Avatar
Those tens need space to breathe. With the seat in the way, it's hard to get the sound right. I knew a guy that had a little bandpass box on the passenger side on the floor, and it sounded good. Not too practical, though.
Old Mar 1, 2011 | 06:55 AM
Bojangles's Avatar
True, but the secret to getting around that is to stuff the box with cotton, it makes the speaker think its in a bigger box.
My two tens were rolling down my windows when maxed out, and they sounded amazing.
Old Mar 1, 2011 | 06:56 AM
scottishb's Avatar
Hey, don't be afraid to put big power to the doors! I had a Blazer with like 600 watts (600 REAL watts) going to all four doors, sounded crazy. Had to keep up with six 12s in the back...
Old Mar 1, 2011 | 06:59 AM
scottishb's Avatar
You lose a lot of bass from the seats canceling out sound.
Old Mar 1, 2011 | 07:19 AM
Bojangles's Avatar
True, but like i said, i had mine set up right, and it would put them boys with 12's to shame.
Old Mar 1, 2011 | 07:44 AM
Bojangles's Avatar
Hope this is descriptive enough, I did this in my spare time at work lol
Use 1/4" or 1/2" plywood, PLENTY of wood screws, and caulk from the inside and out, carpet them whatever color you like, go to wal-mart and get a bag of cotton, use half the bag for either side, then set your 10's in and your good to go.
Old Mar 1, 2011 | 09:07 PM
drift_king's Avatar
alright dude sounds good thnx if i get the money ill come on here and tell u how it worked out thanks for the ideas
Old Mar 2, 2011 | 09:39 AM
Bojangles's Avatar
No problem let me know what happens
Old Mar 3, 2011 | 01:21 PM
drpdmazda's Avatar
try to stay away from plywood if your building a box. although plywood will work, it is not the ideal type of wood to use as a subwoofer box. I suggest using MDF to build the box with. Depending on your budget and the type of sound you desire you can go a few different ways with the system. you can use one 4 channel amp and use 2 of the channels for your door speakers, and you can bridge the remaining two to power a single 8",10" or 12" sub depending on the amps rating and the subs rating. or if you want to go louder, you can run two 2 channel amps, one for the sub(s) and one for the door speakers. there are several ways to do it, its mainly going to depend on your budget.
Old Mar 3, 2011 | 01:34 PM
1988mudder's Avatar
Yeah It can be done for sure...I actually had 2 12" subs in one box behind my seat...it took a good bit of lookin to find a box that would work, but i found one, It didnt sound awesome, but they were only 20 dollar walmart subs so i dont know how much you can take from that! haha but I mounted the amp to a piece of plywood that was covered in felt, and it worked awesome! Hope this helps
Old Mar 5, 2011 | 06:22 AM
yotanasty757's Avatar
I would get a ported box, go to a local audio store and get them to build you a box specially made for your truck, its the best way to go, it does cost a little money to do, but your system will sound great and not distorted, hes right, it does need some breathing room, but with that, you should get all new door speakers and throw some tweeters in it. Good radios that have great sound quality are kenwood or clarions, both extreamly good radios
Old Mar 7, 2011 | 02:54 PM
Miguel's86Toy's Avatar
so i have an extra cab nd im way into systems =]
i suggest running two 8's they are small yes but in your case smaller is better you can build a better sounding system with the same amount of room =]
im running two re audio 8's and they sound really good and i have a big amp so they are running on way to much power (because i plan on getting two more)
oh keep in mind too that one sub in a very well designed box (built to the specs of a sub) can sound much better then two in a not so hot enclosure =) have fun with your subs haha
post some pictures also i would like to see the build
Old Mar 7, 2011 | 03:40 PM
BigBearSteve's Avatar
I must be lazy, I just put one of these behind the passenger seat
http://www.bazooka.com/products/mobi.../BT-Series-S69
And an Amp behind the other side.
icentropy
Sep 16, 2020 02:47 PM
nanhodges2733
May 29, 2020 03:28 PM
Poncho0206
Jul 10, 2015 06:21 PM
bryan34w
Jul 6, 2015 05:53 PM
