Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Need help installing 6x9 speakers in my toyota pickup doors.
Old Jul 30, 2010 | 12:28 PM
BlackDiamond's Avatar
Well as the title says, I have some nice speakers that came with the truck, its just I want to install them into the door so I can put 2x 12 inch sub woofers in the back. I would like to install them into the doors, I have them in boxes right now its just Id like them in the front so my subs dont over power my speakers. My truck is a '92 extended cab Toyota pickup.
Please help! Thanks!
Old Jul 31, 2010 | 10:30 PM
MarcBallz's Avatar
gooooooodluckkkkkk!
i installed 6x9s in my rear passenger side but i had to cut door pannle to make them fit and it worked butt the window now hits the 6x9 so it dosent go completely down but well worth the boost in audio.
and for the front you cant install the 6x9's or at least i couldn't do it. but my runner is a 99. so now i have 2 4" rockfordfosgate up front and 2 db 6x9 in rear plus a bazooka sub in cargo
Old Aug 2, 2010 | 11:42 AM
First off, Thanks for the reply! I decided to switch to a smaller speaker. 6x9 wont fit anywhere in my cab unless there in boxes behind the seat.
Old Aug 2, 2010 | 03:15 PM
MarcBallz's Avatar
No problem, yeaa that's the only way I could put some 6x9 but I managed to put a pair the the passenger side doors but that's it.
Old Aug 2, 2010 | 04:30 PM
drpdmazda's Avatar
do you have wing windows? if so you can fit a 6.5" there pretty easily, not as much sound and bass as a 6x9 but still better than the 4" stocks. you may be able to get lucky with a thinner 6x9 like a lower end pioneer but would be safer off with 6.5" in my opinion. with or without the small wing windows, remove the door panel and roll the window all the way down. now you can get an idea of what will fit if anything and where, you already address the clearance issue with the window down. get to that point and post up some info or some pics and we can go from there if you want some more help.
good luck
jason
Weidle
Jan 21, 2019 05:39 AM
Yota.Jay
Mar 6, 2016 11:02 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
zytra
Jun 24, 2015 08:14 AM
paxanders
Jun 21, 2015 06:29 AM
