Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
How to wire accessories to come on with the ignition.
Old Aug 19, 2009 | 10:06 AM
deathrunner's Avatar
I'm trying to clean up my wiring and am trying to figure out how to get accessories to turn on and off with the ignition. There are several that I have in mind so I would just like to power a whole fuse block via ignition.
Do I just tap into a fuse on the stock block and power my accessories fuse block with it? Do I use the ignition to activate a realy to turn on my accessory block?
Here is what I want turned on with ignition:
-inline noise filter for cb
-aux headlamps
-aux rear light
-air compressor
-aux cig lighter
-subwoofer
Any suggestions?
Old Aug 19, 2009 | 10:36 AM
seanmearse's Avatar
The subwoofer should turn on with the cd player and amp. One positive fused to battery, one remote and a ground, then the amp should cut on and off with the sub.
Old Aug 19, 2009 | 01:12 PM
eric-the-red's Avatar
I would use the ignition to turn on a relay to power the auxiliary fuse block. I used one of these fuse blocks from Painless, it has constant hot and ignition hot circuits
http://www.painlessperformance.com/w...&SearchAll=4x4 OffRoad
Old Aug 21, 2009 | 08:09 AM
Of Course! Duh! I should have thought of that. Thanks Eric.
The sub is already on the remote. good call, Sean.
Old Aug 22, 2009 | 12:47 AM
seanmearse's Avatar
Now if I could only figure out my internal regulator conversion.
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
anniesball
Jul 29, 2015 11:46 AM
nickb3
Jul 21, 2015 10:00 AM
