Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Help with aftermarket stereo receiver and factory Antenna
Old Mar 22, 2012 | 12:53 AM
traxxi2003's Avatar
Question Help with aftermarket stereo receiver and factory Antenna
Hello everyone! I need help with figuring out how I can make the factory power antenna to work with my aftermarket Pioneer DDin FH_P8000BT unit. The wire harness that came with the new receiver has a "blue/white" remote cable. The manual says to connect the amp remote cable or the auto-antenna relay control terminal (max. 300 mA 12V DC). Currently I have both of my amps remote cables connected to this cable. My questions are: Can I safely connect the antenna relay to this cable eventhough I've already have two other items connected to it? Second, Where is the antenna relay located on my 1997 4Runner SR5? and lastly, Which cable from the mentioned antenna relay do I have to splice and connect with the receiver's "blue/white" remote cable? Thanks!!!
Old Mar 22, 2012 | 04:35 AM
worshipmentor's Avatar
If you are that concerned about over drawing the blue-white power feed just drive a relay with it and let the output of the relay drive any and all other "power on" devices. FYI- I don't have an antenna but I drive 3 power amps and an EQ from mine with no problems.
My motto?
"when in doubt, RELAY it out"
Old Mar 22, 2012 | 04:37 AM
traxxi2003's Avatar
Okay Thanks worshipmentor!!!
rusty904
Mar 27, 2017 05:20 PM
theking11863
Mar 19, 2016 09:36 PM
shisha1999
Sep 20, 2015 11:35 AM
msged2007
Aug 22, 2015 07:46 PM
corey519
Aug 12, 2015 11:12 AM
