Front Speakers Not Working
you can test the speakers once they are removed by using a low voltage cordless drill battery or a 9volt battery. I have a 9 volt battery with wire soldered to each terminal. by touching the wires from the battery to the speaker it will cause it to "pop" or move, in some rare instances i have seen a blown speaker pop, but not usually. if they move they should still be good.
voiddweller
19
May 2, 2016 09:10 PM
