Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Door wiring help
Old May 2, 2006 | 08:35 AM
junbug's Avatar
Door wiring help
hello,
im trying to mount component speakers on my door. everything is mounted already. im having a heck of a time routing the wires through that rubber piece where all the door wires are running through. is there an easier way of running the speakers wire through? any help will be greatly appreciated!
Old May 2, 2006 | 09:36 AM
bigacuralvr's Avatar
I used one of the ling 12-15" zip ties. Cut off the square end, tape the wires to one end, and feed the zip tie through the grommet. It'll go, but it may take a few tries. Thats how I do it...but thats just me.
Or, you can mount the crossover box in the door, and use the stock speaker wire. Then you don't have to worry about running new wires through the grommet.
Brett
Old May 2, 2006 | 10:34 AM
junbug's Avatar
thanks biga! i really appreciate it.
Old May 2, 2006 | 12:40 PM
mdh's Avatar
mdh
I pulled the door boot from the door and removed the kick panel. I think I pushed a screwdriver through the boot to make sure there was a "path" and I lubed the wire with some soapy water to make the pass easier.
The zip tie sounds like a good idea though.
Old May 3, 2006 | 08:20 PM
Bumpin' Yota's Avatar
the zip tie is a great way to do it or you can get those 24" long mechanical fingers...
lubing up the area with WD40 makes it SUPER easy to pass stuff through those grommets.
Old May 8, 2006 | 09:52 AM
junbug's Avatar
i finally mounted my tweeters on those triangular plastic piece located by the side mirrors. i did use the coat hanger and it wasnt that difficult. i have the tweeters installed with the aftermarket 4" speakers under the dash and so far it sounds pretty good. i will door mount these 6.5" speakers once i have the time. too busy with work right now. thanks for the help guys!
Old May 8, 2006 | 09:56 AM
HUTCHSTACO's Avatar
I do the zip tie thing, works great
80Truck
Oct 12, 2025 07:25 PM
westonian18
May 1, 2020 06:38 AM
94yotaky
Jul 23, 2015 07:50 AM
jackiebrownia
Jul 20, 2015 09:02 AM
toyota32
Jul 6, 2015 05:42 PM
