Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
BUMPIN for $200...
Old Feb 12, 2008 | 11:38 AM
notanymore's Avatar
Originally Posted by runner4thebeat
So 2 subs is over doing it? I was looking at one Square Kicker but are they better sounding or just look different?
ps.
http://cgi.ebay.com/2-Rockford-Fosga...QQcmdZViewItem
these two then i need 2 amps? around 500 RMS? what about a 800-1200 watt amp and running both of them? Amps are real expensive compared to subs..
you would only need one amp, either get a 2 channel amp that will put 200-300w rms a channel @4ohms or get a mono amp that puts out around 500w rms at 2ohms and wire the subs in parallel. you should be able to find a good amp on ebay for <$150 pretty easily, just dont get a no-name amp or something like sony.
visonik is a cheap walmart grade brand, dont do it, it doesnt put out 1000watts. unless the amp is cea compliant it proabably doesnt put out the wattage that it claims. Also peak wattage doesnt mean very much and its the rms wattage that you need to look at.
Old Feb 12, 2008 | 03:02 PM
runner4thebeat's Avatar
Originally Posted by Johnnyanger54
1 12' in a 4rth order is nothing to sneeze at... Just wire a single 4ohm dvc to 2 ohm (parallel) and it will pound.. The little MTX RT202 is a great little sub amp for one driver at 2 ohms... I currently have that hooked to a 10 Adire in my wifes dodge QC in a sealed box and it has nice crisp bass... Like i said, just get an OK 12 inch sub, throw it in a 4rth order, and you'll be happy.. The thing about bandpasses is they make crap subs sound decent, they just have a very narrow freq range but they are extremely effcient in that range so not alot of power is needed for big boom boom... Like i said, score yourself a little MTX202 and a single 12.. kaboom... mirror rattling bass, not "knock yo dick in the dirt bass" but definatly boom... HTH
and this can be done for under 300 depending on the sub you buy.. if you get a kicker comp (100) and the MTX amp (120max) youre into it for 220 and have good boom... the better the sub the better the sound, but again BP dont care what you put in them.. Ive heard 2 Jensens in a BP with a BOSS amp sound good before, its all in how you build the box and what you tune it to... The box will make the setup..
Mike
you had me real confused but then i did some reading and i think im a little ok now..So if I were to get a Kicker Comp VR 12" that says is 2 ohm DVC, and i hooked it up to a 300 watt amp(RMS) at 2 ohm, i'd be pretty good? Is that the setup your talking about? Oh and i know about the bandpass box.
Old Feb 12, 2008 | 04:57 PM
JohnnyRanger54's Avatar
If you find a 2ohm DVC only hook up one VC as if you hook up both you'll show an 0 ohm load at the amp and unless you are going to buy an amp for thousands of dollars it will blow the amp... Just get a 4ohm DVC sub, wire it on both VC, that will present an 2 ohm load at the amp (which most amps are rated for) and youll get the most bang for your buck... Ohms law, google it.... basically you cut in half for each thing you hook up.. so lets start here..
Say you have a 4OHM SVC sub.. Wire it up, you have 4ohms, no ifs ands or buts
Say you have 2 4 ohm subs, wire them together, cuts teh ohm load to 2 ohms.
Basicall a DVC will give you more options in wiring, so 1 DVC sub is like having 2 SVC subs.... wire your DVC in parallel an violla 2 ohm load.. so on and so on.. say 3 8 ohm SVC subs.. 8,4,2 ohm load wired in parallel. it always cuts in half... dont go lower then 2 ohms unless you have HIGH end equipment rated for 0 ohm load...
Old Feb 12, 2008 | 08:15 PM
notanymore's Avatar
for a 2ohm DVC sub you would need a 4ohm amp or a 1ohm amp, but 1ohms are usually expensive and not super common. http://www.crutchfield.com/learningc...rs_wiring.html for alot picture diagrams wiring diagrams to help you understand the wiring and ohm loads.
Old Feb 12, 2008 | 08:54 PM
  #25
??? Wha??? Dude, he just needs an amp that can handle a 2 ohm load, pref a D class or mono.. he doesnt need an a/b....
Old Feb 12, 2008 | 09:39 PM
  #26
Man you've been great help. I read up on crutchfield and i have a mild understanding of ohm's and all that stuff....Now lol. But i got a little confused on the fact that if I wire one 4 ohm DVC to an amp i'll get 2 ohms but if I wire 2 4 ohm DVC's i get 4 ohms? I thought it was better to get lower ohm's? Or is it because only mono amps can handle such low ohm's? I'm thinking of getting either one or maybe saving up and getting two Kicker CompVR 12" 4 Ohm DVC. Seriously though thanks to all of you for your input you've all been a great help
Old Feb 13, 2008 | 12:22 AM
  #27
notanymore's Avatar
huh? i never said anything about the different classes of amps... the whole left column in that link is for mono amps. i do agree he should go for a mono amp and class D would be a good idea. i was saying he wont be able to get one 2ohm DVC sub to work at 2ohms.
amps put out more power at lower loads so if your going to get 2 of the kickers, 2ohm would be better, that way you can run them @2 ohms (wiring the voice coils in series and the subs parallel) but if you get only one go with the 4ohm and wire it parallel to reach 2ohms.
Old Feb 13, 2008 | 06:16 AM
  #28
I completely misread what you said, my bad.... I wasnt bashing... but yeah BTTT..
The less the ohm load, the more power that can travel (less resistance) so more wattage is what happens... now go buy some stuff and hook it up!!
Old Feb 13, 2008 | 11:31 AM
  #29
notanymore's Avatar
no worries
Old Feb 14, 2008 | 06:40 PM
  #30
What do you guys think about Rockford Fosgates P2's and P1 models? I have an opportunity to buy the p1's for 50 each and the p2 for for 75? Big difference? good brand?
Old Feb 14, 2008 | 07:27 PM
  #31
89trknwby's Avatar
are looking for brand new equipment? if not, check pawn shops , and ebay. i've had MTX subs, JBL subs , orion subs, kicker subs and JL audio subs. the JL's sounded the best by far and hit the hardest. they had clearity(?) deep bass , punch.
Old Feb 14, 2008 | 07:49 PM
  #32
Youll be happy with either fosgate, they're both decent subs.. If you were going sealed id say go higher quality but youre not soooooo..
JBL subs never impressed me in any enclosure, MTX subs and Fosgate subs are about equal as they are pretty much the same same, Older orion stuff is the shizz!! JL is great stuff, just no W0's the sound very muddy no matter what you do with them, same with w1's.. go for the fosgate, cheaper and good...
Old Feb 14, 2008 | 07:51 PM
  #33
If you go used or can find one on ebay try to get an Adire shiva, tempest, or brahma, Adire went out of business but theyre subs kicked MOFOing ass for the money.. you can get an adire tempest or shiva used for about 75 bones... Thats my 2 pennies..
Old Feb 14, 2008 | 09:09 PM
  #34
notanymore's Avatar
i used to have a P1 12" in my truck hooked up to a pos lightning audio amp and it hit HARD for how much it costs, my rear view mirror was useless when turned it up and would fall off occasionally when i had my music up loud. with only 150 watts it hit harder than my infinity with 400 watts does. i wouldnt hesitate to recommend them. I havnt heard a P2 but with the quality of the P1 im sure it will please you.
Old Feb 14, 2008 | 09:26 PM
  #35
yotaman84's Avatar
haha. look up this amp. hifonis brutus. made by maxxus(who makes mb quart) its 2000 watts rms and 4k peak. $350. alpine has some loud stuff as does jl and of course kicker. i have a set a Hertz 12s that were in my truck but now my car and its redic loud and very clean. idk man i could tlk your ear off about subs and speaks nd amps. so if your lookin for a prime system for cheap just send me a personal mail and i can tell ya the best for the price. stereos are kinda one a my passions so ive been researchin um for some time and can help you. just stay away from car toys and anything those places carry
Old Feb 14, 2008 | 09:37 PM
  #36
yotaman84's Avatar
if your not worried about a warranty check out onlinecarstereo.com smoken deals
Old Feb 14, 2008 | 10:30 PM
  #37
notanymore's Avatar
that amp screams ebay junk all over the description, you know its bad when they misspell words in their description of their amp. there is no way you can get any kind of quality 2000w for less than $300 so just stay away. with amps like this if it seems to good to be true it is. I wouldnt buy any amp unless its CEA compliant, otherwise they can say how ever much wattage they want.
Old Feb 14, 2008 | 10:41 PM
  #38
that amp screams ebay junk all over the description, you know its bad when they misspell words in their description of their amp. there is no way you can get any kind of quality 2000w for less than $300 so just stay away. with amps like this if it seems to good to be true it is. I wouldnt buy any amp unless its CEA compliant.
AGREED!!!!! Im not going to start bashing but yeah, hi-fonics is junk... you CANT buy 2000watts for 300 bones.... if you want a cheaper decent amp thas big power JBL1000.1.. its close to 500 bones and puts 960RMS at 2 ohms.. BLAH BLAH BLAH BLAH BLAH.... Oh and thats also rated at 13.4, not 18.8 like the junk amps to claim bigger numbers.. Just go get yourself that little mtxrt202, you cant beat it for 100 bux.... its a real amp, no power house but will pound a 12 in a 4rth order... Youre on a budget, live with it.. When tou get some cash look at Sundown Amps and start Strappping them or orion amps...
Old Feb 16, 2008 | 02:52 PM
  #39
OK i think ive finally decided..
Kicker CVR 12" DVC 4OHM-$85 at a local audio shop
http://www.crutchfield.com/App/Produ...111&tab=review
how bout this amp?
Profile Ha700M~$100
http://www.crutchfield.com/App/Produ...9HA700M&tp=115
and of course a box?
will this work at 2ohms?
You think this will bump good with a ported box?(or bandpass whatever you guys think is best)
Old Feb 16, 2008 | 03:29 PM
  #40
bigt's Avatar
i would get the kicker sub for the amp...
kicker stuff is nice... i have the old kx400.1 mono sub amp it would run that 12 nice...cause i run 2 of them hahahah...but i upgraded to the kx600.1 which is 600 watts instead of the 400..
