Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Boston Acoustics - SL60
Old Sep 4, 2007 | 05:14 AM
KZN185W's Avatar
Hi,
has anyone with a 3rd gen 4Runner used the Boston Acoustics SL60 component speakers? how was the install? did it block the window mechanism?
thanks!
Old Sep 9, 2007 | 08:11 PM
rocket's Avatar
Depth could be a concern but it's the speaker mounting holes that could be a bigger problem.
The 6.5" components (Polk) that i tried didn't line up..the holes were spaced more like 6".
So then i tried 6.75" components but the body (magnet side) was too wide to fit the stupid factory adapter and the mounting holes still didn't line up! I could have trimmed the factory adapter but then depth might have been a problem.
(The OEM speakers have a 1/2" thick ring that moves them away from the door).
I ended up making my own "ring" adapters to mount the 6.5" components.
Whenever i finish installing everything, i'll have a picture heavy write-up.
It would still be nice to know what after market components will fit (front doors) without any modifying. All the websites that tell you what fits is wrong.
Old Sep 9, 2007 | 08:56 PM
89macrunner's Avatar
there are TONS of speakers that you can throw into a taco\3rd gen
BUT very few of them will fit with an adaptor so modifcation is usually needed.
What i did is I cut apart the old speaker, saving the ring that attaches to the mount on the door. Than I lined up the new speaker with the piece from the OEM speaker and drilled holes. I sealed them together with a generous helping of silicone. After Letting the silicone dry for awhile the speakers went in no problem.
this is with my 2000 Taco, but you will run into the same issues with your 4runner. I had to drill holes for the tweeters and used the included flush swivel mount.
I have Alpine Type-R's BTW
OK so here are some pics, the first shot is from my tacoma, the rest are borrowed from Rock Slide's install thread. (hope he doesnt mind)
these should really help make your install smooth. There are 1000 places to throw the crossovers..i put mine under the kick panels.
Old Sep 9, 2007 | 09:34 PM
nieuwendyk-25's Avatar
Search under speakers and you will find a ton of write ups and pictures. I made my own adapters with MDF...real easy. I also have a write up about installing 6.5" components in the rear doors of a 3rd generation 4runner. If you want any picts just PM me. I used 6.5 inch Focals in front and rear and they sound awesome...such good bass response, I decided not to put in a subwoofer...and I already ran the wires for it.
Look here and here
Old Sep 9, 2007 | 10:21 PM
rocket's Avatar
89macrunner,
I really considered doing what you/RockSlide did..in fact, he had the ONLY thread i could find that was worth getting ideas from. Nice job.
I chose to make ring adapters instead because i wanted a super clean/flush install with the speakers mounted away from the factory adapter. I also wanted the rings to serve as a dual purpose; helping to reverberate sound.
I still have a lot to do but so far i'm happy with the way my install is going.
nieuwendyk-25,
You (along with elton's pics) had the only other helpful thread. IMO, theres not a ton of info or pics for installing after market (front door components) in 3rd gens.... but there will be when i'm done.
Old Sep 10, 2007 | 07:15 AM
Yeah I need to post my entire write-up...at the time I did it, I was having trouble with my server and I never got back to it. I'll be real interested to see your install when it is done.
Keep us posted!
dixietaco96
13
Jul 17, 2004 08:12 PM
vtruong1
10
Mar 12, 2003 10:10 AM
grimace80
28
Feb 27, 2003 02:47 PM
4FonZ
Aug 4, 2002 02:25 AM
