Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Basic Amp Wiring Question
Old Jun 28, 2005 | 08:35 AM
WraunVT's Avatar
I have installed half a dozen amp/sub setups and have always wondered
is it better to run longer RCAs to the amp and have the amp next to the sub -or- mount the amp under my seat and run longer speaker wires to the sub.
I assume there will be less signal loss with the longer RCA and probably less interference (since they are shielded). But how does that compare with the cost? I know I am a cheap b@stard. That is not the question here Long RCAs and thick power wire are considerably more expensive.
Hit me with your thoughts y'all.
Old Jun 28, 2005 | 08:38 AM
964runner's Avatar
speaker wire is definetly cheaper and, i dont thing you will see noticable difference either way you wire it
Old Jun 28, 2005 | 09:23 AM
97Limited's Avatar
I Think longer speaker wire is better then RCA's
The RCA's carry the nice clean signal and the longer they are; the more chances to pick up static!! and its never good to go cheap on your RCA wires!!
but really you will never really hear the difference!!
Good Luck Man!!
Old Jun 28, 2005 | 09:39 AM
DavidA's Avatar
Longer speaker wires, shorter RCA.
Old Jul 6, 2005 | 01:04 PM
noahrexion's Avatar
exactly...
In all my experience the shorter the RCA's the less distortion you will hear
Old Jul 6, 2005 | 03:14 PM
DavidA's Avatar
Speaker wire is running a much higher wattage than RCA's.
RCA's run at 2-5volts, making the signal vulnerable to picking up interference from other electrical wires/devices. Plus your amplifier of course amplifies the interference that was picked up by the input wires. The speaker wires are beyond that and pick up little or no interference. So shorter the RCA's the less likely you will pickup any problems.
Sleaker
Aug 26, 2020 06:03 AM
DrZero
18
Jul 24, 2015 11:31 PM
rushw
Jul 18, 2015 01:46 PM
msane99
Jul 17, 2015 10:13 AM
88yodabasket
Jul 13, 2015 01:32 PM
