2003 4runner power locks.
please help locating the power lock wires. if you have done it please let me know. here is the only wiring diagram i have.
POWER LOCK BLUE (TYPE B) IN DRIVERS KICK, 18-PIN PLUG
POWER UNLOCK GREEN (TYPE B) (Requires Double Pulse) IN DRIVERS KICK, 18-PIN PLUG
sounds like you already found them - that 18 wire molex in the kick.
The door locks are a negative interrupt, that is the circuit for them is broken on the ground side. And then completed to lock/unlock the doors. Using a DMM you should be able to figure out which wire suddenly carries 12v (in reality carrying ground) when you hit the switch. There will be one wire for lock and one wire for unlock.
Jun 1, 2021 01:51 PM
jon.r
Jul 11, 2015 03:34 PM
skoti89
Jul 8, 2015 12:05 AM
