Site Feedback Please use this forum to provide feedback, suggestions on the site
Just died at the pump.
Old 01-13-2020, 06:59 AM
Ram1's Avatar
Died at the pump..... Don't know a lot about the fuel system on the 96 Toyota T100 V6 but I'm dead in the snow. I know this isn't the place to post and I already posted on the newbie forum with no help. Have great fire just doesn't seem to be getting fuel. There also doesn't appear to be a Schrader valve to test the fuel pressure. Can anyone give me a clue. I guess I need to buy a vowel here. Please help.
Old 01-14-2020, 09:58 PM
STERFRY333's Avatar
Fuel pump? Check the OBD2 port (i think a 96' would have one, not sure on it though)
Old 01-15-2020, 08:48 AM
rattlewagon's Avatar
Check your fuses, mainly the efi fuse.
Old 01-17-2020, 01:00 PM
Ram1's Avatar
Died at the pump
The truck started up a few hours later and drove it home. I don't think that it would start again if the fuel pump was bad. It has quit on me again a few times but started right back up afterwards. It seems as though it has a week circuit or a short somewhere. Yesterday I was driving down the road and it died and restarted a few minutes later. I purchased a new repair manual and I plan on running down the whole circuit. Can't help but think that there's a short or loose connection, bad relay, or worse bad computer. May just be a bad ground somewhere. I'll figure it out and let you all know what I find out. I was just wondering if someone else had this trouble and what they may have found the problem to be. Safe travels all. Thanks for your help and input, always appreciated. By the way is there a place to advertise yota stuff for sale on the forum?
Old 01-17-2020, 05:48 PM
Cameron Croucher's Avatar
Almost guarantee it’s the fuel pump
You said it will will start and run for a bit well my dads fuel pump started to quit and that’s exactly what his did. It would start and run but die shortly after. A side note you should change your fuel filter as well if your gonna put a new pump in mine was disgusting.
