Site Feedback Please use this forum to provide feedback, suggestions on the site
96 Tacoma losing power
Old Dec 3, 2005 | 04:44 PM
96Tacoma Guy's Avatar
My 96 4cyl 2.7 tacoma is losing power in the lower rpm's (2,000--3,000 range). when it is idling it keeps surging up about 100-200 rpm's. It just started doing this, I drove it 80 miles and everything was fine. Anybody got an idea on what to check? I have done the following without any luck...added fuel injector cleaner, check the sparkplugs,efi fuse, and air cleaner all seem okay. Help!
Old Dec 3, 2005 | 05:58 PM
midiwall's Avatar
Where are you in the world? A lot of places are now in "winter gas" which can cause some fun.
The idle surge is probably more telltale than the midrange power loss. It sounds like it may be starved for something to burn.
How long has it been since you added the injector cleaner? It can take a while for it have any effect.
When's the last time you replaced the fuel filter? Have you ever replaced the O2 sensor? Have you tried cleaning the MAF? Cleaning the throttle body?
How many miles are on the engine?
When you say "I drove it 80 miles and everything was fine", do you mean that you had trouble, then for 80 miles it was fine; or that you had driven 80 miles and then had trouble? Was that 80 miles right after filling up? Maybe you got a bad tank of gas...
Search here for the "big thread" talking about SeaFoam - that can help in general.
Old Dec 5, 2005 | 09:27 AM
DudeBud's Avatar
also like to add why is this being posted on site feedback you will have better luck in the right section
Old Dec 5, 2005 | 05:46 PM
oly884's Avatar
Guest
I'm going to second this.
Old Dec 5, 2005 | 05:49 PM
Rivalred's Avatar
Air Idle Control Valve or Maybe MAFS maybe? .... Flux Capacitor?
Old Dec 5, 2005 | 07:02 PM
rngrchad's Avatar
Could it be the dreaded TPS sensor......?
Flying91
45
Apr 11, 2024 04:39 PM
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
94whiterunner
Jul 12, 2015 07:15 PM
Poncho0206
Jul 10, 2015 06:21 PM
