toyota rear into jeep?
Old Jul 1, 2005 | 09:24 AM
Tacoma750's Avatar
You guys know of any writeups of doing a toyota rear in a wrangler? Thinking about it, but wanted to get some feedback first. Anyhelp would be great.
Old Jul 1, 2005 | 07:49 PM
BeaterToyota's Avatar
A YJ Wrangler or a TJ Wrangler?
A YJ should be no problem, assuming the two axles are about the same width. Just pull the crappy Dana 35 out, cut and reweld the Toyota spring perches to match the spacing of the Jeep's leaf springs, and bolt it on. You would get a pretty big lift by doing this since you'll be going from spring under to spring over.
The brake lines would need a little bit of attention 'cause the Jeep stuff is probably SAE and the Toyota lines are metric.
I know I've seen where people swapped a Toyota axle into a Cherokee, but haven't heard of doing it in a Wrangler.
Old Jul 1, 2005 | 09:20 PM
Cedarbarn's Avatar
Why not go for broke and put some Unimog axles under the Heep?
Old Jul 2, 2005 | 12:14 AM
Yamaha+Toyota=Fun's Avatar
What do you need to do that for?
Gravel Maker
RuffStuff
Jul 6, 2015 07:43 PM
Gravel Maker
Vendor Advertising
Jul 2, 2015 12:57 PM
Gamble_STi
Jul 1, 2015 12:51 PM
cchinny
Jun 25, 2015 08:11 PM
