Single Cab Bumper Build
Old Jul 21, 2012 | 09:22 PM
TylerH's Avatar
Progress has slowed, Been to hot to really do anything. I can really only work from 7:30-9.
But latly ive been trying to find and match the angles to make the recessed lights look correct. Plus finding the correct pipe. I really need 4 1/16''- 4 1/8'' inner diameter thin wall pipe. But 4'' outer will have to work. So i purchased about two feet of 4'' exhaust pipe and went to work finding the angles. All is good just needs to get cut out and welded/grinded in. That i may do tomorow or thursday.
It may not be 100% perfect but its works for me.
Old Jul 22, 2012 | 06:12 AM
matstaley's Avatar
So what would a guy have to do to get copies of your patterns? I live over here in Bend and my uncle is a long time local in Oakridge. Floyd Staley. You might have heard the name. Anyway, do you think that pattern would fit an 86?
Mat
Old Jul 22, 2012 | 09:26 PM
TylerH's Avatar
Yea i know floyd. Ive know him ever since i was like 5. Im suprised he hasnt asked for my metal scraps yet, jk.
Anyways i wasnt planning on doing anything tonight but today was alot cooler then it has been like the whole month. So i figured i might as well.
Got the torch out and decided it was the quickest way to blast some holes. I have not used a torch in years so bear with me.
Did some grinding. Figured out using the 4 1/2 angle grinder with worn out disks worked the best.
Put the bumper back on and slid the light "buckets" into place. They fit well for using a cutting torch and grinding. Next step is to tack them and then start building the mounts to hold the lights.
Here is how they look with the lights in place. I like it, i think its going to shine well with HID's. I think i will only be able to run 35 watt lights because the heat and also cause the lights are plastic.
Old Jul 22, 2012 | 09:28 PM
TylerH's Avatar
Mat
About the pattern, we can figure something out. Maybe ill make a cad diagram of it or draft it out on paper with the anlgles and measurements.
I dont think its would fit an 86. I think the parts by the fenders would look weird.
Old Jul 23, 2012 | 05:33 AM
  #25
matstaley's Avatar
Yeah, its only a matter of time on the scraps. Its a staley thing. We're scroungers. Lol. Always lookin for a deal. That bumper looks sweet.
Old Jul 26, 2012 | 10:18 PM
  #26
TylerH's Avatar
So i got a little bit done today. Got the buckets tacked into place and i think i got the angles correct. Started working on the brackets. The brackets on the lights have a really wierd mounting system. All i could think of is using all-thread. Im not a big fan of that stuff but i think its going to have to work. I will take some more pictures tomorow on the mounting system.
Anyways on with the pictures.
I know i tacked them a dozen times to many but i was having fun. And i didnt want them to break off when i lifted the bumper off.
I saw these on ebay a few days ago. I used to have these on my truck before i hit a deer and i was really happy with the light output for the price. So i had to have them. Im thinking i will mount them ontop of the bumper. But i dont know yet. If the recessed lights are bright enough i may just sell these.
Old Jul 27, 2012 | 08:06 PM
  #27
TylerH's Avatar
A few updates. Went and picked up parts, also worked on it for a little bit.
The mounting system, Holds well.
Old Aug 1, 2012 | 02:16 PM
  #28
TylerH's Avatar
Had today off so what better way to spend a day off then throwing sparks!
Welder was not welding well. I dont know why. It looks bad but holds well
Not done grinding, still have to do the one side then fill in the pits then regrind.
But untill then its lunch time.
Old Aug 1, 2012 | 02:32 PM
  #29
Teuf's Avatar
What welder are you using, and its setup?
Old Aug 1, 2012 | 02:51 PM
  #30
TylerH's Avatar
Its a lincon 220v. Dont know the model and im using 80/20 argon i believe.
Old Aug 2, 2012 | 07:58 PM
  #31
TylerH's Avatar
Figured out it was the little gas holes in the welding tip, They were full of slag.
Didnt feel like throwing sparks today so i drilled the holes for the blinkers. Using a hole saw in steel is not as easy as i was hoping.
Ill post some picture in few minutes.
Old Aug 2, 2012 | 08:15 PM
  #32
TylerH's Avatar
One battery down.
Victory!
Random picture of the front angle, almost done with the grinding.
Adding another peice under the corner for extra strength, and protection.
Old Aug 9, 2012 | 09:21 PM
  #33
TylerH's Avatar
Have not had much time to do much till tonight. Got alot done tonight. Went over alot of my welds, filled pits. Grinded and did some more filling pits. I think tomorow i will grind more and weld on the shackle mounts. Havent decided if im going to powder coat or just paint. And also havent decided if im going to cut the hole for the winch fairlead.
I dont have the winch yet, but the hole would really help air get throu.
Any idea on how to get all the oil off from cutting the blinker holes. I was going to use brake clean, but that sometimes leaves a residue.
Old Aug 11, 2012 | 05:25 PM
  #34
matstaley's Avatar
Mineral spirits will do it.
Old Aug 11, 2012 | 09:29 PM
  #35
TylerH's Avatar
Here are some updated pictures. Just need to touch up some welding pit marks, and regrind. And smooth out some of the corners. Weld on shackle hangers and paint.
Was getting alot done and then i ran out of gas. O well, more likely i wont be able to fill the tank till friday.
The blinker is not pushed in all the way. Its still really sharp and i didnt want to risk cutting the rubber. Fog light is also not mounted, just sat in there. It will be more centered when the time comes.
Old Aug 18, 2012 | 07:29 PM
  #36
redmufn's Avatar
thats a lot similar to mine, check it out. although i wanted to recess some lights in like you did but didnt get the chance to. youll love it man ive had alot of fun with mine
Old Aug 22, 2012 | 08:09 PM
  #37
TylerH's Avatar
Got Some work done in the last few days. Got the shackle mounts welded on. Got all the corners welded and ground smooth.
All i have to do now is grind the welding splatters, touch up the edges and sand. Going to hit the thing with some 220 on the D.A. and see how it looks. I will snap some pictures tomorow.
Old Aug 23, 2012 | 08:08 PM
  #38
TylerH's Avatar
I got everything packed up for the night and then i remembered to snap some pictures. So i took some really quick. Sorry for the quality.
It came out pretty well, all the angles are good. Could be better but will look fine once i add some texture and real paint. This is just primer btw.
Old Aug 25, 2012 | 09:52 PM
  #39
TylerH's Avatar
Its not done completly, wanted to put it on to see how it looked. See how the weight made a differnce. And the people at my work didnt believe i was doing anything cause its been a slow process.
I still need to alter some mounting holes, cut off a peice of the bottom mount, Drill hole for cb or dune antena, sand it, add texture, Paint and install the fog lights and wire everyhing. It will be done wednesday i hope.
Old Aug 27, 2012 | 07:06 PM
  #40
TylerH's Avatar
A few day light pictures.
