The "Official" 3rd Gen Gas Tank Relocation Thread!
Originally Posted by dragr1
You need more skids than just that!
Chris
Do you have a BL, cause It should tuck up nicely when you remove the cross member. My cross member is cut out and raised 2" off the top of the frame and is made of 2" square tube, same as my sliders and rear bumper. There is plenty of room up there. You might get better weight distrabution if you move it closer to your bumper, but departure angle might be reduced.
Originally Posted by Hyperlite
Do you have a BL, cause It should tuck up nicely when you remove the cross member. My cross member is cut out and raised 2" off the top of the frame and is made of 2" square tube, same as my sliders and rear bumper. There is plenty of room up there. You might get better weight distrabution if you move it closer to your bumper, but deparcher angle might be reduced.
Chris
#25
Originally Posted by RockComa
I remember that tank
Chris
#29
I have a skid from an Isuzu Trooper I was gonna modify for my fuel cell but might part with if you can't find yours......
Chris
#32
hey Chris, what is the capacity of that Isuzu tank? Is it the same as the original or larger?
BTW I have found a donor tank for my swap. Its from a 65 mustang (16 gal.) brand new. It fits perfectly in the frame rails. I will be starting a thread about it in the next couple of months.
#33
I would think a larger tank would be ideal, at least for me. With so many vehicles on the market, there has to be a couple that will fit perfect and have the same side fill port.
keep the pics coming Chris!
#35
Chris
#36
Chris
#37
I agree. but it is the same size as I have now and I am gaining a lot of ground clearance.
Chris
#38
Originally Posted by ravencr
That's the whole reason I'm doing this mod. It's all custom fabrication, wiring, tubing, etc.
Chris
Chris
#39
Making the tank connection was a lot easier than I expected, that's for sure. That's the part I was worried about, but now that that's behind me, I've just got ot come up with a solid way to mount it, but plus be able to remove it if needed. Running the tubing and wiring is going to be simple. My excitment it the idea of cutting out the freakin' crossmember for all that added clearance. I can't wait!
Chris
Chris
#40
Stock=18 gal
Mustang=16 gal
I like chris' tank, and gaining 3 gal.
