Need more lift in fron 4x4 04 tacoma spacers?
Old Jun 7, 2008 | 01:23 PM
yellowpasta2000's Avatar
Hi i have a *4X4" 04 tacoma and have a 1.5" spacer above the coilover. How much actual lift would this give to the truck?
When i see people saying 2.5" spacer or 3" spacer is that the actual size" of the spacer or is that the over all lift it will give the truck?
I want to lift the front of my truck higher because i have 33.2"bfg a/t tires and it rubbs when I turn.(also have a 3"wheel spacer installed) How can i go higher? I also have a 1" diff drop instaled. remember its 4x4 so im limited with the axel angles...
All your help will be appreciated! Thanks!!!
Old Jun 7, 2008 | 01:51 PM
crolison's Avatar
coil spacers are bad, get some new springs and struts or some adjustable coilovers to lift you up. Usually the recommended max lift is 2.5" for cv angles.
Old Jun 7, 2008 | 02:08 PM
max lift is 2.5 inches but i do have a 1 inch diff drop so would that maby let me go to 3"?
Old Jun 7, 2008 | 02:20 PM
crolison's Avatar
Most suggest 2-2.5" but many have gone above that and have had no problems, and some have. I am currently running a tad over 2" and originally i had around 2.75" and my cv angle wasnt the best, but wasnt too bad. I have manual hubs sitting in my room and when those go on I am gonna crank the front up a little more.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
Yotoder865
Jul 9, 2015 07:51 PM
akaphilly
Jul 9, 2015 02:18 PM
