Ford 302/351 swap info
Old Nov 19, 2005 | 07:24 AM
stevenassco's Avatar
IMO you need to set some goals if you are serious about this
-what is it being used for? Mud, rock trails?
-how much power do you want?
-what is a realistic budget?
These make it much easier. IMO I would simply just get a used stock mustang 302 roller (HO) FI engine out of a fox body complete for like $500ish and go from there. They came with forged internals and can be pushed to 600rwhp if neccessary, parts are overflowing out of every corner of the market, technology is booming for it etc. It is a relatively light and compact engine as well. Get one, slap a 8psi supercharger kit on and you can have a reliably 400hp engine no problem for relatively cheap, get good fuel economy, be docile as well.
if you got a 351, you could stroke it to 408+, but again, parts are much more money, do you really need 700hp?
Old Nov 19, 2005 | 09:35 AM
DudeBud's Avatar
yes i do
Old Nov 19, 2005 | 11:27 AM
JamesD's Avatar
Originally Posted by EWAYota
Heck, with that attitude, stuff this in there
Check this link out: http://www.cardomain.com/ride/651079/19
James
Old Nov 19, 2005 | 10:59 PM
colsoncj's Avatar
Im still swaying back and forth between the 302 and 351.... its goina be one of those. 300RWHP would be more than enough for me. it all just kinda depends what i come across first cheap, 302 or 351.
Correction on the trannies... 89 F250 2WD had a E4OD... but i dont know if you could get it in a 4wd... I havent figured out what axles im goina wind up usin yet... but im leaning towards non-toyota. still thinkin bout narrowing a wide front to use for rear steer... but the more i look at different front axles, the more i think its not possible.
Old Nov 19, 2005 | 11:17 PM
  #25
Originally Posted by DudeBud
yes i do
well if you do 700hp reliable HP is not cheap, not matter how you slice it. I would recommend a 351W with forged internals, standalone an a single turbo kit. That will get you 700hp and still fit under a 2nd gen hood!
Old Nov 20, 2005 | 08:16 AM
  #26
ecchamberlin's Avatar
If you are thinking Fuel injection I would stick with the 302 (5.0) becaue the EFI system is easy and parts are really available. Could easily push 350hp with out a turbo or sc'er. Keeps it really reliable. Just go with a 1990 or newer so you have a Mass Air engine instead of a Speed Density puter system. I hope you do this either way. Your Runner will be a monster.
Old Nov 20, 2005 | 08:49 AM
  #27
colsoncj's Avatar
How much different are the fuel injection systems between the 351 and the 302? Which 302's where roller setups? IIRC there were no roller 351's right?
Old Nov 20, 2005 | 10:06 AM
  #28
DudeBud's Avatar
i was just kidding anyways but, it would be very fun at the least.
Old Nov 20, 2005 | 10:20 AM
  #29
DudeBud's Avatar
there are roller 351 blocks lightnings used them but any 351 block can be roller if you get a spider kit as for the injection other than the intakes being wider and the plentem being taller im not sure
Old Nov 20, 2005 | 10:31 AM
  #30
JamesD's Avatar
Exclamation
I can answer this for you. The FI systems are the same. Roller 302's in trucks started somewhere in 88-89. Roller in 351's I think started in 94-95 in the trucks. Your best bet is a 302 for fitment reasons. The 351 is too wide. Here are some of the specs:
302= W 18 3/4" & 20 3/4" H
351W= W 21" & 23 3/4" H
Length depends on what front timing cover you use. On the average it is 27 1/2"
Height is measured from bottom of oil pan to top of valve covers.
I would stick with the 302 since more parts are out there for them. Some 351 parts with swap with 302 like, timing cover, cylinder heads(302 is 7/16" bolt holes, 351 are 1/2" but the 302's can be drilled or the 351's can be used on a 302 with a bushing adapter), upper intake if it is FI, cam, rockers, exhaust manifolds(depends on application) and some brackets for accessories.
What you can use is the HO motors since they have forged pistons, roller cam and dual roller timing chains. These are in Mustangs, Lincoln Mark 7 LSC's from 85-92. You probably want speed density system meaning non Mass air unless you are planning on putting cam or any other mods in the motor. For what you are doing, the HO speed density motor will work perfect for you. You will have plenty of torque, great idle and cool sounding exhaust. If you are interested in any parts, let me know. I have just about everything you need.
One thing more I forgot to mention. You can build one hell of a stroker motor for the 302/351's at a very reasonable price. How does 347 cubic inches sound just by using a 302 block? They would give you TONS of torque if for some odd reason you werent happy with just the SD HO unit.
James
Old Nov 20, 2005 | 10:33 AM
  #31
JamesD's Avatar
I just noticed you have an LS1 sitting in your driveway. There you go, problem solved!
James
Old Nov 20, 2005 | 11:42 AM
  #32
colsoncj's Avatar
LOL the ls1 is staying where its at plus ive been told they wont fit, too big
what kind of numbers did the HO 302's put out HP wise... I'd like to be around the 250 to 350 RWP range when its all said and done. If figure around there i'll have the power to do what i want, but not soo much power i'll need huge beefy axles.
Thanks so far for all the help!!!!
Old Nov 20, 2005 | 11:53 AM
  #33
JamesD's Avatar
Its not the horsepower you need to worry about for what you are going to do. Now I have personally seen to the rear wheels in mustangs on stock and mostly stock setups with stick put 207-235 down depending on many variables. But what is nice is the broad torque range these put out for stock. Again 260-290ft. lb of torque on a dyno. The torque is like from 2500-5000rpms which is exactly what you need. If you want 250-300 to the wheels you can change the intake or put heads on it for roughly 250-300. This is assuming it is stick. Heck a mild cam can get you that but you need to convert to mass air. The above numbers are with mass air systems. Stock speed density vs stock mass air, the speed density makes more hp an torque do to the fact that the mass air meter is very small and it causes a restriction. PM me if you need anything.
James
Old Nov 20, 2005 | 11:54 AM
  #34
JamesD's Avatar
One other thing. You can use a SBC but the Ford fits better since it is narrower and the distributor is in the front so you dont have to worry about firewall issues.
James
Old Nov 20, 2005 | 12:34 PM
  #35
colsoncj's Avatar
Thanks James... the note about a SBC... thats one of the many reasons im goin Ford
Old Nov 20, 2005 | 07:05 PM
  #36
kyle_22r's Avatar
i was gonna post the cardomain site about the guy who booty fabbed a 390 into his toyota. then again, at least he had the cajones to give it a shot. i never would've imagined a big block would ever fit in a toy bay...
i thought about doing the 302 swap, the only thing that held me back is that i would never run an auto tranny, so you're limited with viable options: go with a huge NP435 4 speed, use an adapter and run a G or W tranny(bad idea imho, too weak) or spend a bunch of money on adapters and put in an NV3550.
the ford is a little bit longer than the chevy, but lacks the distributor clearance problem and the width is nice. then again, i've seen a 350 swap that looked like it fit great in a toyota, so i guess everything is possible. go for it!
Old Nov 20, 2005 | 07:11 PM
  #37
colsoncj's Avatar
you could use a T18 or T19..... good small trannies
Old Nov 20, 2005 | 07:19 PM
  #38
DudeBud's Avatar
same size as np435... there are many trannys out there that can be used t-5 or t-56or a toploader would be nice or an nv4500 I have been thinking about switching out my t-18 for one for the overdrive.
Old Nov 20, 2005 | 07:30 PM
  #39
colsoncj's Avatar
I didnt think the t18/19s were that big... hmmmm
Old Nov 20, 2005 | 08:29 PM
  #40
DudeBud's Avatar
yeah take a look here http://classicbroncos.com/tranny-t18.shtml
almost forgot about a ZF tranny that would be another good one
