engine swap
Old Nov 3, 2004 | 06:23 PM
50Runner's Avatar
thats the problem...
What good is a truck if I can't romp on it? The second I get it in deep san/mud that thing is going to come apart...
I think I need something stronger.
manuel
Old Nov 3, 2004 | 06:40 PM
Nathan Buchanan's Avatar
Why not the NV4500?
Old Nov 3, 2004 | 07:04 PM
50Runner's Avatar
Its up there...
I would just like to find something that I can fit without having to do a body lift or doing transmission tunnel modifications.
If I can't find anything that I can get away with without having to do those modifications then I'll go with the NV4500.
manuel
Old Nov 3, 2004 | 07:06 PM
Got ya. You think you could fit a L/C tranny without a body lift? Well, you need an overdrive so that prolly wouldn't work.
Old Nov 3, 2004 | 07:08 PM
  #25
50Runner's Avatar
5spd
Well, there is that 5SPD that came in foreign land cruisers. Maybe that would work. I actually hadn't thought about that.
manuel
Old Nov 6, 2004 | 12:19 PM
  #26
I know you said you need an overdrive
I have a C4in my conversion it works great, but I could diffinatly use an over drive. I'm interested to here your decision + results. fellow 5.0
Old Nov 15, 2004 | 03:19 PM
  #27
fiveofeen's Avatar
4 cly manual T-5 has a different size input shaft. it will fit and work but its not a clean fit in there and will screw up things. its also not as strong (duh) and has a higher gear ratios. the WC t-5 is a good tranny its downfalls are from too much power, banging the gears (especially power shifting) D&D transmissions in wixom, mi are the folks to talk to. you can rebuild t-5 to handle your power, its already rated at around 260hp 320tq
you could always throw a C4 in there, they are plentiful and tougher than crap. but its an automatic.
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
