1st gen 4runner winch bumper
#42
I thought your bumper looked very similar to the one on Trail-Gears website, but then you said you made your own, so i was just curious if there was any connection there. Great looking bumpers.
#43
Yeah, TG doesn't even offer a bumper at this point, just the winch mount. I may be having a local place redesign the mount to not have to space the tubing up above the plate, but at this point, I just cannot beat their price for it. We'll see how that plays out. In the meantime, these are pretty much in full production at this point.
#58
Earlier your said these holes would be stripped out under a winch load. I can't imagine the frame brace would aid in strength with that unless those holes were threaded. Are they threaded? If not, did you just thread bolts into the original frame holes? Or did you do that and put a nut on the other side? Could you get a nut on the two outer bolts that thread into the end of the fully-boxed framerails?
#59
The other option is that you can easily place some 1" welds randomly without having to deal with the frame brace. This will spread the load and should be fine for winching.
FWIW, All-Pro and Marlin bumpers also recommend welding the bumper on once installed. All-Pro even sends two tubing gussets with their bumpers.
