Doh. No more 4wd
Any guesses as to what might have caused the damage? Was it acting up before... impact or water... lack of use (hard to believe
I feel for you man. You have a lot on your plate transitioning at this point in your life. I wish I new more about the systems you will be dealing with.
If you want to put a R150 tranny behind your 3.4 and a manual case I might be able to help you with that.
).I feel for you man. You have a lot on your plate transitioning at this point in your life. I wish I new more about the systems you will be dealing with.
#25
I would love a manual transfer case.
If it would work and not interfere with the electronics. Lets do it!! Do it, do it!
After about 6 days of being home I'm headed back to do more signing up here.
My goal is to fix it in one way or another by them.
Heading back to town on Tuesday.
(Oh yah, it started taking longer to engage into 4wd. The last time it worked it took a LONG time. 111db was there on a box canyon run. I may have hit it a bit as there is a slow oil leak from it. Now it does nothing... nothing at all.)
Want me to suggest a signing co-rider to the guy here? (I found out that most folks use a co-rider to operate the trimble gps and you get paid the same as the driver)
#27
#28
Hell yah. Congrats. are you at the rei near me? I just got back so I'm going to go by and check right now!
#29
#31
#33
#35
Kinda. Among yotatech folks is unheard of because it only has to do with 01-02 runners. they are the only ones with the lazy mans electronic transfer case.
Its nice to have awd in snow driving or high speed dirt driving which the earlier years don't have. Keep in mind that mine has 130k miles and I put on more offroad miles than most so it gets a lot of wear.
The best runners seem to be a 99-00 with the rear elocker which is also unavailable on the 01-02 runners. Unless you are getting the good looking 02 gray color. That color is worth the problems alone!
#37
They have 2wd, awd which is 4wd with the center diff unlocked so you can safely drive on pavement, 4wd with center diff locked and the a-trac system activated and 4wd low.
95-00 have
2wd, 4wd center diff locked, 4wd low, and then if they have a locker they can go 4wd low with locker on.
#39
This what my FSM says in the Transfer Troubleshooting section:
Shift from 2WD (H) to 4WD (H) impossible
1. 4WD fuse -
2. Wire harness -
3. Vehicle speed sensor - BE-45
4. 4WD position switch - TR-9
5. 4WD indicator light - TR-9
6. Actuator assembly - TR-49
7. A.D.D. control system - SA-48
8. 4WD control ECU - TR-49
9. Transfer assembly - TR-3
I can get you those sections it refers to if you don't have the FSM already.
1. 4WD fuse -
2. Wire harness -
kawazx636
Oct 6, 2021 03:03 PM
Cycles
Sep 29, 2015 06:37 AM
May-39
Sep 6, 2015 01:05 PM
