Florida Florida Chapter
Abs Brakes
Old Aug 19, 2008 | 01:25 PM
coconut's Avatar
Abs Brakes
any one in the miami/ft lauderdale area with a 04runner that has the vstrack,tracoff,abs light on?what is the cure! i disconnected the negatoive term in the battery and refconnect. same problem, had a technician plug in an onboard meter and was told that the sensor is bad. is this possiaBLE. ANY ONE KNOW HOW MUCH THE SENSOR IS OR CAN YOU JUST REPLACE THE HARNESS OR THE SENSOR. ANY ANSWERE WOULD BE APPRECIATED FROM ANY ONE.
Old Oct 2, 2008 | 03:30 PM
condor's Avatar
4 runner ABS/TRAC/VSC lites
Mine come on when I get a little skid on a dirt road while braking. First time it happened, all those lights came on, and I did a search on this web site and a guy told me to unplug the ABS plug (on the brake master cylinder, along with about five other plugs) while the engine is running, turn off the engine, plug the ABS back in, and restart the engine. This should re arm the system. It took a a couple of times before I got it right. Can't remember which plug it is, but a car manual might show which one it is. Hope this helps.
1uzRunner
63
Nov 10, 2018 03:58 PM
old87yota
Sep 9, 2015 12:39 PM
Scatterbrain
Sep 3, 2015 06:46 PM
flg8r22
Aug 30, 2015 10:59 AM
ty1er
Aug 1, 2015 11:53 PM
