North Carolina North Carolina Chapter
Final Lift Config. Opinions Please??
Old Feb 24, 2004 | 08:03 AM
Stump1883's Avatar
Okay guys, looking for the best bolt on and go system I can afford this is what I've come up with, let me know if this should take care of everything.
Rear suspension kit ON SALE $559
Rear 56" long travel springs
5100 Bilstein shocks (I will be opting out for the 5150s)
1.5" longer greasable shackles
Extended rear brake line
Rear Perch kit or flip kit
Heavy Duty spring hangers
Front Long Travel Springs(4" lift) ON SALE $199
All Pro Front Shock Hoops $89
Bilstein 5150s 2 shocks $178
All Pro Hy-Steer $449 = $19 IFS Box mounting brackets
- I already have a box off of my 86' parts Runner
That in my mind takes care of most everything I need for the suspension and steering to be upgraded. Please please let me know what you guys think of this set-up, I really need the input b/c I've never delt with a system like this and it's a bit intimidating. ALL suggestions welcome.
Old Feb 24, 2004 | 10:02 AM
Hyperlite's Avatar
looks great!!!!!
You might want to have all pro throw in the axle rebuilt for you ($100) and has ever seal and bearing needed to overhaul your front end
Now all your gonna need is a cool rear bumper like mine
Old Feb 24, 2004 | 12:22 PM
NCSU-4runner's Avatar
add: extended front brake lines
the axle rebuild is definetly a good idea, one tip: when you rebuild the axle do it one side at a time, not all together. helps keep things separated. and it doesnt come with EVERY bearing, you would have to buy the main wheel bearings (the real big ones that go around the spindle) somewhere else (napa etc, def not the dealer they are $$$ there, like $40 each and there are 4 total) but you'd hear it when you drove the truck if those had gone south cause they spin fast and hold the weight of the front end of the truck. the rebuild kit only contains the steering pivot point bearings
Old Feb 24, 2004 | 05:40 PM
ssbogger's Avatar
Originally Posted by NCSU-4runner
and it doesnt come with EVERY bearing ... they are $$$ there, like $40 each and there are 4 total
Ehhhhhh... that sucks!
Flying91
45
Apr 11, 2024 04:39 PM
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
Sep 4, 2015 09:27 AM
kirkrunner
Jul 27, 2015 07:59 PM
Yotoder865
Jul 9, 2015 07:51 PM
