Washington Washington Chapter
Questions on you Vertical-hungry people *ahem* ROB&DAVID
Old Sep 17, 2003 | 04:52 AM
2001Millrunner's Avatar
im considering some spacers about an inch or two on front and rear, i dont need crazy suspension mod or anything just a better approach angle and stance. I thought this would be a very good alternative that's completly reversable. would you guys recommend this? also this would definitely void warranty right?
and David how are the Bilsteins compared to other brands? would you have done things differently?
Old Sep 17, 2003 | 08:10 AM
Mad Chemist's Avatar
Sounds like you're getting tired of being "height challenged?"
I have OME shocks in the rear, not Bilsteins, so I can't give an opion on them. I know alot of people think they rule. In general, I think spacer lifts are primarily for show. Will they give you added height? Yes. Will they allow you to run bigger tires? Yes. Will they improve articulation/flex while off roading? No. Do you run the risk of trashing your ball joints? Yes. Are they more cost effective than a "real" suspension lift? Definitely.
As far as the warranty for your vehicle, I don't know, and its something you'd have to ask in the general forum. Probably only voids the warranty if you have problems related specifically to the suspension. I like my current setup, and wouldn't change anything.
Old Sep 18, 2003 | 10:36 AM
oops i just saw that since your shocks were yellow it must be Bils...wrong! i have much to learn.
Old Sep 19, 2003 | 02:45 PM
Yoter's Avatar
Guest
Woo Hoo Ray's gonna jack his 4Runner up.
Old Sep 19, 2003 | 07:05 PM
Yoter's Avatar
Guest
Ray, I see your signed on. So how high are we talking, 4,5,6,7,9 inches?
Old Sep 19, 2003 | 07:11 PM
maybe 2inches? i dunno.....Shocks would come first......David can you maybe give me the break-down of what you have? so i can *dream* about it?
Old Sep 20, 2003 | 06:20 AM
How hard is installing new shocks? do any of you guys know of write ups or tips&tricks on this?
Old Sep 20, 2003 | 07:09 AM
Ray,
Changing the rear shocks and coils aren't too bad. The front is kind of sketchy to do by yourself, since you have to use a coil compressor to compress the spring to get the shock out. The advantage of going with SAWS is that you just replace the whole unit, so its a bit easier. From what I know of what you want to do with your 4runner, I wouldn't go with the SAWS. Most people go that route so that when they get an aftermarket bumper for the front, they can adjust with the extra weight. Its more of an off-roading mod, and they run 675.00 for the pair. Since you a pretty new vehicle, I'd probably just go with spacers all the way around, maybe the cornbred aluminum spacers, and get rid of those running boards once and for all! Actually Ray, if you just wanted to "look" taller, dumping the 'boards would do wonders. If you decide to install a lift, we could make it the first official 4ROC wrenchathon, you'd just have to supply the pizza...
Old Sep 20, 2003 | 07:42 AM
Yoter's Avatar
Guest
4ROC WrenchUHthong, LOL
Holy cow! Im up for beer, pizza, and turnin wrenches. Do it Ray do it! I will seriously drive two hours to transform Ray's Runner into a beast. Lemme know when you are going to do it Ray.
Old Sep 20, 2003 | 07:54 AM
KevyWevy's Avatar
i think i feel a 4ROC mod day coming on. hey david you still got that Downey Catologe?
Old Sep 20, 2003 | 07:57 AM
Yoter's Avatar
Guest
Hmm another two inches couldnt hurt. 9"!
Old Sep 20, 2003 | 08:00 AM
KevyWevy's Avatar
when are you gonna go and do the SAS? we could pull the front axle off of Rickey's Runner.
Old Sep 20, 2003 | 08:03 AM
Yoter's Avatar
Guest
Im trying to get my buddy to go in halves with me on a 1st gen with a SAS. Thats down the road.
Old Sep 20, 2003 | 09:42 AM
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2432784403 WOULD ONE OF THESE WORK?
Old Sep 20, 2003 | 09:55 AM
Yoter's Avatar
Guest
Looks good, then you only need another 4.5" of lift
Old Sep 20, 2003 | 12:56 PM
REALLY THO ALL I REALLY WANT IS MAYBE 1.5INCH LIFT, I DONT WANT MY BALL JOINTS SCREWING UP OR CV THROWING UP GREASE. I'LL GET SOME BILSTEINS FIRST THEN THINK ABOUT THIS LATER.......ALSO MY STEERING FEELS A LOT LOOSE DOES ANYONE ELSE HAVE THIS PROBLEM? IS TIGHTNING IT HARD?
Old Sep 20, 2003 | 02:50 PM
Ray,
The Daystar kit would do the trick, but I'd also look at the spacer kit that Revtek makes as well. Check out Steve Schaefer's web site for comparison of the different spacer lifts. My steering is a bit loose as well. They have kits to replace the bushings with better polyurethane ones, I think its a pain to replace, but I've got to do it. If the new bushings don't work, then you're looking at a new steering rack, which go for about 700 from Toyota. I'm trying to ignore it in the meantime.
Old Sep 20, 2003 | 10:55 PM
smr4runner's Avatar
Hey Ray,
Hows it going man.
You might want to check Steve Schaefer's site on the Daystars.
If I were you I would go Confed Spacers or Revtek.
I had the Cornfed spacers for the front of my 4Runner along with an OME suspension setup. It worked out great.
Cornfed is about 70-80 bucks cheaper depending on what size spacers your looking for.
Cornfed
Revtek
Let me know when your ready to install. I would be happy to assist.
Mike
Old Sep 20, 2003 | 11:07 PM
StoryR's Avatar
Funny Kev You little punk
But seriously, I think a mod day is deffinatly needed! I am acually having trouble with my cb...I haven't even tuned it yet, and haven't even used it...but I am no longer getting any reception, I checked the ground wires and everything...no dice...beats me
Old Sep 21, 2003 | 04:48 AM
yea guys thanks for your concerns and helpful hints. I dunno if im just whining but after couple of times of wheeling, my steering is loose, my truck shakes and steering shimmies on freeways, rotors are warped, engine vibrates when I stop in Drive, truck wobbles noticeably more when turning and also durning normal driving , Im slowly noticing these things. Is this a common issue with all of you? im beginning to think 4runners arent tough as i thought they were. My truck is at 39.5k mi. maybe i'm due for a tuneup? any suggestions? and as far as my riding heights I think I can be happy at where i am at right now. I dont wanna rush into things and regret later. Just want my truck to run as good as before and that's my priority for now. I finally took running boards off(because it actually looks better in my eyes now ) . had to cut the mud flaps when i was putting it on because i almost ripped them right off just by turning hard. my factory dunlops looked like glazed doughnuts compared to these BFGs I think my new tires will hold me off for a while as far as mods go. i'm gonna try to get an alignment and get new Bils.shocks and also a tune up, any mechanically inclined people give me some advice on regular maintenance and suggestions on replacement parts? i have not done any scheduled maintenance except oil changes since i bought my truck at 12k last year. and oh yea, i think my Amsoil needs some seriously deep bath. Also he Pinstriping on my truck is noticeable now....I'm also looking into Griot's polish to get the little scratches out. I care about looks and little things too much, I'll always be a newbie...I just know it
