Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
Toyota pick need help badly
Old Aug 3, 2021 | 08:01 AM
Chsse1991's Avatar
Hello everyone
I live it beautiful Hawaii and I have a 93 pickup 3.0 automatic 4x4 n my problem is truck has a pop I guess u can say it starts it runs but u can hear a pop ever so often n wen u go to drive it if u give a little has it starts to fold over untill full throttle n hold full throttle for a second them picks up rpm n goes until it shift n it struggles till rpm builds up again it was so bad that almost to to accident wen pull out to highway did egr delete a few mouths back n truck was running fine no check engine light cane on n still no check engine light is on
so far I changed cap,rotor,plugs,wires,fuelpump,mas,distributor, overhauled injectors,did a egr delete,redid wires for injectors n distributor all soldered and heat wrapped changed temp sender,temp switch,temp time switch, did all that n still the same don't no what else could be
Dre'yota
Nov 20, 2019 03:29 PM
Jroberts3412
Feb 3, 2017 05:13 PM
