Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
Still not starting
Old Aug 5, 2022 | 02:36 PM
norskgubbe's Avatar
Still not starting
Hello again. My 89 4Runner with 22re turns over good but not starting. I replaced the fuel pump and filter. I connected 12v directly to the pump and it pumps fuel but when I put a jumper on the DLC FPand +B I get nothing and I tested for power with the key on@ the circuit opening relay 5 pin connector and no voltage. I checked all the fuses and none are bad. Am I overlooking a relay or fuse. Please help and thank you for reading and any help. I have spark on all 4 and 150# compression on each.
Old Aug 17, 2022 | 03:52 AM
jeremy harp's Avatar
if there is a spark try to look at your fuel injectors
Old Aug 17, 2022 | 06:22 AM
norskgubbe's Avatar
No start issue fixed
At the diagnostic connector I connected a wire from Fp to battery positive and fuel pump runs. I removed the circuit opening relay and one side tested good the side bad. Replaced it and it runs.
norskgubbe
Aug 7, 2022 09:53 AM
norskgubbe
Jul 9, 2022 11:51 AM
