Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
Oil gauge fix
Old Dec 9, 2016 | 04:01 PM
Davemc's Avatar
Oil gauge fix
you can fix the oil gauge/sender link for your 3.4 by removing the oil gauge, sender and zeroing the gauge to match your sender. You need an air source, a 12v source and a air gauge setup for a compressor. Set it up like this. Bend the bi-metal strip in the gauge to start at zero. Put some air in the sender. I have 15 psi in there for the first reading. Second stage - I have 58 psi in the - gauge is about half way up. Reinstall sender and gauge. Enjoy not spending $180 on a new sender.
Attached Thumbnails Oil gauge fix-img_0538.jpg   Oil gauge fix-img_0540.jpg   Oil gauge fix-img_0541.jpg   Oil gauge fix-img_0542.jpg   Oil gauge fix-img_0539.jpg
Last edited by Davemc; Dec 10, 2016 at 07:31 AM. Reason: unclear that this was for a 3.4
