Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
lighting issue
Old Apr 15, 2017 | 08:19 AM
truckertrex's Avatar
lighting issue
1982 toyota pu 4x4 front lights all work dash lights work,Tail lights work but the brake passenger side signal or either hazard on the rear don't work ?
Any help appreciated !
Old Apr 17, 2017 | 08:17 AM
coryc85's Avatar
Ok, so you are saying that only the rear passenger side turn signal does not work, did you pull the bulb and check it? Sometimes you can visually see that the filament is broken, but if it looks ok, you can swap it to the other side and see what that does.
onmyway
Aug 4, 2016 12:57 PM
