Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
Hard Starting after Warmed up
Old Dec 4, 2023 | 01:56 AM
Mhelvestine's Avatar
Have a 1997 Four Runner 481,000 miles Started having an issue with starting up after it gets to temp. was looking at the forum and they mentioned that the fuel pressure regulator might be th issue replaced it, was not the fix I was looking for. Seems that once it gets warmed up I need to crank longer to get it started then sometimes it misses and tries to cut off like it loading up. Haven't really had too many problems with this yota that's why i'm keeping it. Cold has no issues could be 25 degrees outside and starts right up.
Old Feb 8, 2024 | 10:05 PM
joelle king's Avatar
How often do you change oil ?
Old Feb 9, 2024 | 01:23 AM
Hard Starting after warmed up
With this Yota having 481000 miles on it , the oil gets changed every 5000 - 6000 miles, usally it's not really even dirty when it gets changed. Its dark but not filthy.
Feb 10, 2024 09:07 AM
Jayden Hall
Jun 20, 2023 11:49 AM
