Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
'87 2WD 22r electrical problems
Old Feb 26, 2016 | 01:31 PM
Dismalbogs's Avatar
5 Year Member
Hello,
This is what I understand happened, as I was not there when it occurred.
A friend drained the battery. Thinks he crossed terminals trying to jump it. He got a jump from AAA and he, on their advice, replaced the battery.
This is where I arrive.
I replace the burned out 80A fuse. It begins to turn over again. No Spark. Resting voltage on igniter is 12v. The coil showed a resistance of 9.5ohms. I cannot find the specs for Toyota part 90919-02106.
Will replace the coil but I don't think it needs to be. I have the feeling I should be looking for fused connections.
I am stranded in an expensive city with little money and could really use some ideas for further diagnosis and possible workarounds.
Thank you
Old Feb 26, 2016 | 01:32 PM
Dismalbogs's Avatar
5 Year Member
Can we move this to the electrical section of the repair and maintenance section?
Thank you
Henrythewound
13
Jan 12, 2016 07:18 PM
Patricia Ringo
Dec 15, 2015 10:53 AM
85toyman
Dec 14, 2015 03:34 PM
